Electrical Bugs
Electrical Bugs
Im having an issue with my sc300 that I recently purchased well two first of all my power locks, trunk button and interior lights do not work checked fuses and they are all fine. Could it be a relay? And secondly when i steer left on a turn the wheel stays left and when i turn right the opposite happens. Could this be the steering rack bushings or just new tie rods?
Thank You
Thank You
For the trunk lock. It could be that the key socket beside it is locked. Just use you're key to unlock it.
Now for the power lock, does the unlock botton work? If so, then there can something wrong with the factory alarm module.
If its just the keyless remote. There should be an on/off button near the driver side knee panel.
Yes I checked already I made sure that I locked and unlocked the trunk lock. And as for the remote unlock it hasn't worked either I did flip the switch to see I it worked but nothing, also the power door locks do nothing. I have noticed that I am missing gauge warnings when I turn the key on car and I have no chime
TRD_Power
07-24-17 09:41 AM
REDRAIDER
02-19-11 12:58 PM
Nikkc1
01-27-11 05:00 PM
