how to remove stock projector out of headlight housing?
https://www.clublexus.com/forums/sc-...move+projector
found this thread but it still seems ambiguous as the 8mm bolts arent releasing my projector at all... as i twist them they're still staying in the same position.... mmm or ..im not even sure whats going on here. any thoughts?
OK nevermind!!!! weirddddddddddd!!
so to answer my own question and that other guys:
1. you remove the two long bolts by twisting them clock wise( tightening them). that allows the project to come forward.
2. you remove the third section (which also has two screws attached) by using a 10 mm wrench and turning counter clock wise.
- ive never seen two components attached with two different torque directions on the same part. nifty.
seanjonstu
06-24-06 07:58 PM
200, assembly, casing, ct, headlight, headlights, housing, lexus, light, proejector, projector, projectors, remove, removing, sc
