Some goodies to install!
I DID have a time trying to remove the stock one. I could feel the bottom bolt, from the top, ...but couldnt get anything on it. I ended up jacking the car up, and pulling the undercarriage plastic, ...so I could get on it from the bottom. If it wasnt for that, ..it wouldve been a 20 min job.
If yall are interested, ..it came from eagleautoelactric, on ebay. Ive used them before, with good results. http://cgi.ebay.com/ebaymotors/New-L...item53e8c23f4e It's definatley alot of amps, for the money. Some of the 250-300amp alternators run $400-500. I could probably use a 250 amp, ...but with the 1200 amp power cell, ..it should be ok. Between my two amps, ....Im running close to 2500 watts, rms (true watts, ..not inflated max numbers). And, ..then Im running two Viair 480 pumps, ..but those only run for 30 seconds, anyway.
Btw, ...the cable that I ran to the battery, ..is one that you can buy from harbor freight. Its a inverter cable set. http://www.harborfreight.com/6-ft-30...set-96249.html Fits perfect! I just put some 1/2" loom on it, ..for like $3.
I'll be using the black, for some extra grounds (cut up, with soldered ring terminals). Should have enough to do two from the block to the battery, ..and two from the battery to the chassis. I might add one from the top bolt in the alternator, to the pass side chassis,...just to make sure everythings tied in together.
Does your whine, at all?
Mine whines a bit, when I first crank the car. My last one on my supra, was a 160amp, ..and it didnt whine at all.
Thanks for the comments. Yes, ..it's just some vht engine paint. I tried duplicolor 500 degree clear, ..and it SUCKED!!! So, I picked up some rustoleum 2000d clear, and it worked mucho better.
The color is burnt copper. It looks almost as good as automotive paint. The clear didnt die back much, after curing. Looks like a orange/copper pearlescent base color. Its kind of close to the anodized orange, on my K sport c/o's.
The stickers just came from a popular auction site. They were $9, ...but paypal reversed the charges, ...and I have no idea why. So, I guess they were free. :/
Btw, ...in case some of you decide to use the rustoleum clear that I used. If you put it on thick like I did, ...it takes three days to get to where its cured enough to handle. I put about four coats, only letting it get tacky, in between. Im gonna let them sit one more day in the sun, and wax them. That'll keep brake dust from sticking, and make them easier to clean.
that dc going in the rear lid? thats gunna be ALOT of sub for tht flimsy rear deck? any plans for it? tht alt is sexy, this is maken me want to add a system to mine....have had one my whole life. recent was 4 8's 2k rms, daily tune of 32hz low end monster for the win
Heck no, ...it's in a 1.75cu ft (net) with a 4" aero port tuned to 34hz. Im working on the trunk, still.
