Mounting bolts for 97-00 SC fog lamps?
^^ That's what I'm about to do. Thanks!
Update:
For anyone interested, I used metric bolts measuring 5mm x 0.80. The actual length was an odd size from Lowes. They take an 8mm wrench. I bought a few crush washers and used those in every location.
The side and top bolts should be exactly the same. Then there is just the 5mm x 0.80 nut on the back.
Update:
I had a set of the factory bolts ordered too. For anyone buying any 97 foglight hardware as a whole kit and who wishes to use even the factory bolts and nuts, here are the correct P/N's:
x2 Nuts (rear of housing) 90179-05088
x4 Screws (top and side of housing) 90159-50225
Lexus does not list any screw for the side mounting points but the top one is an exact fit, so order four total.
chrispy
11-04-06 11:26 PM
