SC- 1st Gen (1992-2000)
1UZ + Nitrous
Old 08-11-11, 06:28 AM
jdms13
jdms13's Avatar
i have a nitrous kit sitting at home... just never thought about putting it on the sc4... I was a big nitrous guy when i built hondas WAY BACK IN THE DAY... gonna start the mods to get this car ready for some juice... when i install it, i will use a direct port kit and take some pics!
Old 08-11-11, 08:51 AM
xspsi6
xspsi6's Avatar
The 1uz is a crappy motor for making power on as a stock b18 will make about the same power as a 4.0 v8 1uzfe so I am sure it will wake up on spray but the internals are glass much like a Honda.
Old 08-11-11, 10:33 AM
ihiryu
ihiryu's Avatar
I dunno about glass....
I've ran 15 psi on my 1uz in my MKIII. I've run it super lean and hasn't done anything...
Old 08-11-11, 11:16 AM
levie
levie's Avatar
keep cl posted with your results if you do it, good luck
Old 08-11-11, 11:27 AM
GS FONZy
GS FONZy's Avatar
Originally Posted by V8KLLA
I will have a tune on the car for sure
What kind of tune will you for sure have?
Old 08-11-11, 01:06 PM
xspsi6
xspsi6's Avatar
I am not saying it won't handle it for a while but when push comes to shove the internals will exit the block if trying for bigger power numbers, I wish it were a more stout engine because then I would stick it out in my own sc400 but when compaired to a jz inline 6 it just can't make the power per dollar and be reliable all in the same breath.
Old 08-11-11, 01:11 PM
LiCelsior
Retired
LiCelsior's Avatar
my friend ran a 100shot Zex kit on his SC400 and it was conservative.
Old 08-11-11, 01:13 PM
BigBang
BigBang's Avatar
Originally Posted by Sidesweep
Hah. Punny.
Yeah i thought the same lol.
Old 08-11-11, 01:20 PM
V8KLLA
V8KLLA's Avatar
I plan to install a wideband and an S-AFCII. I have a buddy who tunes a lot of cars, big HP turbo cars, so I'm gonna get him to hook me up and get the A/F ratios nice and safe. Plus, running a wet kit also helps since it sprays the additional fuel to support the nitrous.
I've seen people run 150 shots on stock 5.0 Mustangs all day long, you telling me that that old pushrod motor is built stronger than the 1UZ that Tpyota dumped millions of dollars into when building it??
Old 08-11-11, 01:30 PM
cmh
cmh's Avatar
if ur engine is well kept... id say go for a 100 shot but start with a 75... more fuel afc or something to control mixture, use a wet kit and get a wideband (a good one). i ran a 125 on my g35 when it had like 30k miles, with a walboro pump, intake headers, exhaust and plenum spacer and the engine blew after like 7-8 months of using it almost every day... lol... nitrous is a dangerous toy.
question, our engines, are they at a 45 degree or 90 degree angle (the V)
i know the g is 45 which is garbage for FI. (from my personal experience)
Old 08-12-11, 12:31 PM
GS FONZy
GS FONZy's Avatar
Just make sure your fuel pump, lines and injectors can support the added fuel that your tune+nos shot will require. The only thing I would say you are missing from your list is an rpm switch and maybe a trans cooler.
Old 08-12-11, 03:51 PM
GS FONZy
GS FONZy's Avatar
FYI, there's a feature on your safc that can be used as an RPM switch as well, but you will have to wire up relays.
2jzgobrap
01-09-15 05:09 PM
soarer13oy
Performance & Maintenance
18
09-23-10 04:57 PM
Brendon
01-08-09 06:12 PM
JDMmuscle
73
04-06-08 10:23 AM
GlacierIS
12-03-06 09:23 AM
Quick Reply: 1UZ + Nitrous
