SC- 1st Gen (1992-2000)
Ordering CCW Classics this week. Need Fitment Help
Old 07-10-11, 02:21 PM
UpInTheLex
UpInTheLex's Avatar
Default Ordering CCW Classics this week. Need Fitment Help
I'm in need of informed fitment numbers for 18" CCW classics fitment for my SC.
I have the fenders rolled flat front and rear and included pics to try to show the extent of which they are rolled. It's hard to show, but hopefully you'll get the idea.
I also have Supra TT brakes, which require a 5mm spacer for the wheel face to clear the brakes I believe...
So far, I really like Workaholic's (Greg's) SC with the 18x10 front and 18x11 rears.
But, I'm honestly not a real big fan of a stretched tire. Very mild is fine. I also like a low ride height, the car has Stance GR+ coilovers 18/10, but I want something that it's going to be scraping or rubbing while driving just for the sake of looking really badass.
I do plan on driving the car, and I don't want to be ripping the front bumper off or scratching it all to hell.
I don't really want to wear out inside of tires like crazy or loose off the line hook, due to too much negative camber. 1 degree or 2 max, I'm hoping.
Also if I'm wanting the impossible... Someone please set me straight! I may have to compromise somewhere here I realize. Just want to make an informed decision before blowing $3500 on something that doesn't suit my style.
Workaholics setup:
http://photos-d.ak.facebook.com/phot...41119_3647.jpg
Rim Brand and Type: CCW Classics
Rim Size f/r: F: 18x10 R: 18x11
Rim Offset f/r: F:+24 R:+32
Tire Size f/r: F: 245/35 R: 275/35
Attached Thumbnails Ordering CCW Classics this week. Need Fitment Help-photo-4-.jpg   Ordering CCW Classics this week. Need Fitment Help-photo-5-.jpg   Ordering CCW Classics this week. Need Fitment Help-photo-6-.jpg   Ordering CCW Classics this week. Need Fitment Help-photo-7-.jpg
Old 07-10-11, 04:51 PM
Sinistr
Sinistr's Avatar
Got nothing on fitment, but nice Turbo key fob.
Old 07-10-11, 10:55 PM
SChema
SChema's Avatar
This is my fitment, the 17 inch rear fitment will be similar to your 18 inch.
Technically, you could ask for Supra fitment, more exacting specs listed below.
Talk to Dan or John at CCW.
Front: 18 x 10 et44 285/30/18
Rear: 17 x 11.5 et51 315/35/17
https://www.clublexus.com/forums/sc-...-in-today.html
I ran LS400 calipers, so no spacer was required. Instead of the +44 offset you could ask for a +49.
Old 07-11-11, 05:17 AM
Li Ls4
Li Ls4's Avatar
thats the around the same offset i want to run in my rear but on a 19" rim 11 +30ish.
y run the 10 inch in the front if ur gona have a 245 on there? unless ur going for the look.
SChema, how bad were the rubbing issues in front with that 285 while turning? thats a damn wide tire to have in the front on a stock bodies car.
Old 07-11-11, 06:15 AM
Triple C
Triple C's Avatar
18's look small i have a set of XXR's and RFP1's. I like them for drifting but wish i had a set of 19 x 10 +25 and 19 x 10.5 + (15-20) to fit in the stock fendor nd only rub a little. I like mine low. ps , Li Ls4 i run 265 35's all the way and only get a little rub.
Old 07-11-11, 06:57 AM
SChema
SChema's Avatar
Rubbing in the front wasn't too bad all. Only big dips, I was able to get away with aggressive turns with no problems. I was lowered to about a finger gap. Stock fenders in the front and aggressively cut rears.
Old 07-11-11, 10:52 AM
rdt
rdt's Avatar
I have a set of mint ones for sale!
Old 07-11-11, 02:15 PM
UpInTheLex
UpInTheLex's Avatar
Thanks, saw those. I'm going with all brushed clear anodize, lips, centers and center caps.
CASANOVA86
Suspension and Brakes
12-19-10 09:43 AM
TankMR
01-28-10 08:12 AM
madmax98
11-18-09 05:43 PM
STRONG SC
24
06-15-05 01:52 PM
prjctSC300
Wheels, Tires & Brakes Forum
12
09-01-04 08:22 AM
Quick Reply: Ordering CCW Classics this week. Need Fitment Help
