SC- 1st Gen (1992-2000)
Sc400 swap to jdm 2jz-gte questions
Old 07-27-11, 07:10 PM
  #91
souljah798
souljah798's Avatar
Originally Posted by xspsi6
So the sc400 high pressure line bolts right up to the 2jz compressor? I had never heard that before.
Had to go take a look its been 3 years and we're both partly correct, the high pressure side was the one that had to be modified. The low side only had to be bent a little.
Old 07-27-11, 07:15 PM
  #92
account2x
account2x's Avatar
I'm surprised no one mentioned the power steering or fuel lines. Both need to be modified on the SC400.
Originally Posted by souljah798
Honestly in my opinion there isn't much difference between the 300 and 400 when you're talking swaps. The 400 will have the drive shaft and power steering reservoir needed. The 300 will have the upper and lower oil pans needed. Those are the biggest differences when it comes to sourcing parts.
So if I swap a 92-97 SC400 transmission flange onto the Aristo auto transmission I can then use the 92-97 SC400 driveshaft?
LEXXIUM (02-28-17)
Old 07-27-11, 07:16 PM
  #93
xspsi6
xspsi6's Avatar
Aaah thanks for clearing that up.
Old 07-27-11, 07:20 PM
  #94
xspsi6
xspsi6's Avatar
Ps is cake as you just get metric to -6an fittings and use some earls fittings to make that and yes this what I have seen other people do in the past with the aristo trans which seems to work well.
I am not sure what they do for the fuel lines but I am sure it is easy.
Old 07-27-11, 07:28 PM
  #95
souljah798
souljah798's Avatar
Fuel lines are cake also on the 400. It has metal lines that terminate just inside the shock tower. Add some flexible fuel lines and you're golden.
Drift motion has a pre-made ps line that works great. Not a leak in three years!
  #96
account2x
account2x's Avatar
Without the factory vacuum lines you're idle will drop when you turn the steering wheel at idle.
Link
Aristo uses the same 111mm Supra Turbo flange. Only the 98-00 SC400 uses the same 111mm flange. 92-97 SC400 uses 101mm flange which will not fit the Aristo. If I can change the Aristo flange that solve the issue?
Old 07-27-11, 07:39 PM
  #97
souljah798
souljah798's Avatar
I never figured out multiple quotes. That's exactly what I did, but with the 300 trans mount.
Old 07-27-11, 07:48 PM
  #98
account2x
account2x's Avatar
What crossmember under the transmission mount did you use?
Quote twice and copy n paste into the other tab.
Old 07-27-11, 08:05 PM
  #99
xspsi6
xspsi6's Avatar
Link
Yea use the 92-97 sc400 tail shaft housing,flang and drive shaft along with the stock sc400 mount and cross member iirc properly.
Toss the aristo tail and flange in the trash and you will be good to go.
Old 07-27-11, 08:22 PM
  #100
account2x
account2x's Avatar
I want to source a 98-00 SC400 driveshaft and replace the differential flange instead.
Old 07-27-11, 08:24 PM
  #101
xspsi6
xspsi6's Avatar
Just curious as to why?
Old 07-27-11, 08:25 PM
  #102
account2x
account2x's Avatar
To have the larger rubber things.
Old 07-28-11, 05:12 PM
  #103
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Updated question...
If I bought the 2JZGTE and wanted to single it and throw away the stock ones, what needs to be done? Versus just keeping the stock ones.. I was looking at a Driftmotion T67 turbo kit.. Does a intercooler need to be done or is a necassary? Larger injectors, diffferent cams, etc?
Old 07-28-11, 07:11 PM
  #104
account2x
account2x's Avatar
Without the supporting modifications you will not be able to use the single turbo to it's full potential.
Old 07-22-15, 10:17 PM
  #105
driftlex
driftlex's Avatar
Do haft to do a fuel return line for the sc400 aristo motor swap 2jzgte vvti..
If so how .. Not sure I understand that one
Quick Reply: Sc400 swap to jdm 2jz-gte questions
