SC- 1st Gen (1992-2000)
Turn Signal Issue?
Old 06-15-11, 10:13 AM
ihiryu
ihiryu's Avatar
Default Turn Signal Issue?
Hey guys, it's been awhile, I haven't driven the SC much, but I just realized my turn signals arent' working on this bad boy.
The hazards don't work either. I was wondering if anyone could point me in the right direction.
Also I just checked the fuse, and it's good, according to the manual it should be number 8 on the interior fuse panel. I checked it for power with my test light, and it shows there's power on both ends of the fuses (when plugged in, of course).
I got the flasher relay out, and it looks okay. Does anyone know if the hazards should work even without the flasher relay?
Old 06-16-11, 09:18 PM
3rdLexus
3rdLexus's Avatar
Hey, curious if you have any update...
I have a similar problem. When I switch on left turn, the rear blinks faster than normal and the left headlight does not blink at all, nor does the light under it. When I switch on the hazards, the front bottom lights and rear blink normally (1992 SC300) but the turn signal bulb in the left headlight unit does not.
Old 06-26-11, 11:00 AM
RalAegidius
RalAegidius's Avatar
Sounds like a burned out bulb.
Old 06-26-11, 08:51 PM
Warrenlex
Warrenlex's Avatar
Yup. Burned out. Check every turn signal bulb. Even your cornering lights.
Old 10-05-13, 06:22 AM
dlric1
dlric1's Avatar
bump - was this issue ever resolved? i'm having the same exact problem right now...
flyagl
02-28-18 07:53 AM
supraclay
11-12-12 05:06 PM
dtmcabbey
RX - 1st Gen (1999-2003)
04-27-11 08:49 PM
Quick Reply: Turn Signal Issue?
