hydro fan problem
05-25-11, 07:01 PM
hydro fan problem
i have a 1jz with hydro fan and the fan and pulley looks like they're wobbling, changed the clutch and the fan and the same thing
suggeston?
05-25-11, 07:58 PM
Keeper of the light
Quote:
Originally Posted by
ddrsquad
suggeston?
It isn't the clutch or the fan.
05-25-11, 08:41 PM
Check play in your pump to see if that's the cause.
05-25-11, 10:26 PM
O. L. T.
no
MR_Clean
what do i check for?
05-26-11, 01:53 AM
Pull off your serpentine belt, the pully and wiggle the water pump to see if it has in/out or side/side play. If it does then that means you need a new one.
05-26-11, 03:13 AM
you like the hydro fan? if not and its a pain then you can get mk4 tt water pump. if you need a new hydro pump i think i have one for you!!
05-26-11, 10:52 AM
MR_Clean
i just checked it and there is no play
05-26-11, 03:36 PM
05-26-11, 04:05 PM
MR_Clean
is the pully bent?
it doesnt look bent, where can i get a new one?
MichaelK
06-18-13 03:23 PM
frankdms
Performance & Maintenance
07-23-10 08:36 AM
scturbo28
SC- 1st Gen (1992-2000)
07-02-09 10:18 AM
Shellhouse
13
03-21-05 10:52 PM
SC400-V8
Maintenance
09-19-04 04:01 PM
