SC- 1st Gen (1992-2000)
sc alarm problem
Old 05-23-11, 12:40 PM
whiteysc
whiteysc's Avatar
Default sc alarm problem
So 2 days ago my car would not crank after the alarm went off.. I read up on the net and found if I unlock passenger door the alarm would reset it.. It worked but now the car is just turning over and not firing up.. It almost as if the fuel pump is cut off also.. Everytime I disconnect the battery and reconnect it the alarm goes off.. Whats wrong? I really have no clue..
Old 05-23-11, 12:41 PM
whiteysc
whiteysc's Avatar
also my car is a 1992 sc
Old 05-23-11, 01:13 PM
xspsi6
xspsi6's Avatar
Try unhooking the batt for a few mins and then retry and see if it fires up.
Old 05-23-11, 01:24 PM
EM Dot
EM Dot's Avatar
this happened on my 92 a few years back. i was able to to lock and unlock on the driver side and it worked.
Old 05-23-11, 01:34 PM
whiteysc
whiteysc's Avatar
yea I tried to unlock it and it makes the starter turn over but not firing up.. Also everytime I leave the battery unhooked and reconnect it the alarm starts going off again.. I didnt even know this car had an alarm till it started doing this.. I do not have the clicker for the doors and dont know if its the alarm thats maybe keeping the fuel pump from cutting on.. Any more help sure would be appreciated thanks..
Old 05-23-11, 01:35 PM
whiteysc
whiteysc's Avatar
is there a fuse for the fuel pump maybe that has blown or something?
Old 05-23-11, 06:19 PM
tientony
tientony's Avatar
try getting the primary key lock and then unlock the car on the PASSENGER door then try starting it up
Old 05-23-11, 07:10 PM
NEbiker10
NEbiker10's Avatar
TRUST ME On this one lol
Open up ur engine fuse box and pull the EFI main relay, wait 5min put it. it will start.
Lexus had an advanced anti theft on it...a lil to advanced for its own good.
Old 05-25-11, 02:23 AM
whiteysc
whiteysc's Avatar
Hellz yea Thanks for the advice I will try this later today.. I will let ya know if it fixes the problem..
Old 06-24-11, 08:57 PM
whiteysc
whiteysc's Avatar
SO turned out my Fuel Pump went out I replaced the FP today but still not starting for some reason.. I will repost what I find out, when I do find out..
Old 06-24-11, 09:40 PM
TechGreek
TechGreek's Avatar
How did you test the fuel pump out?
My car did this when we set off my alarm (locked keys in car).
Took the key put it in the ignition, tried it - no dice
Took the key out, locked doors from outside twice, then unlocked twice - fired right up.
Old 06-25-11, 07:04 AM
whiteysc
whiteysc's Avatar
First remove fuel pump behind rear seat its pretty easy.. Like9 bolts total.. remove it and then us the wire to test on a battery with 12v and if nothing happens the fuel pump is bad..Also you can look at the connector on the fuel pump itself and if one of the connectors looks burnt .. It is bad for sure..
Old 08-24-11, 10:39 AM
wacoman42
wacoman42's Avatar
The knowledge you can get from this website is crazy
lock my keys in the car (first of many times) Got in with a hanger not
before the alarm shut it down (losing my touch) Locked and Unlocked the
driver side door BAM rolling again. Thanks
tedsterb
12-10-14 08:42 AM
leighv
09-20-13 11:49 AM
saelee39
10-01-07 05:23 PM
yelloa3gti
01-28-07 10:39 PM
Princeton
12-22-06 08:35 PM
Quick Reply: sc alarm problem
