SC- 1st Gen (1992-2000)
Picks of Double Din Aftermarket Nav units installed
Old 08-18-13, 04:20 PM
  #106
Qu0Cie
Qu0Cie's Avatar
I was just wondering when ya upgraded to the double din did you have to get a wire harness or was it plug and play with the factory plugs? Thanks.
Old 08-18-13, 05:06 PM
  #107
RicoLSX
RicoLSX's Avatar
Factory harness is NOT plug and play, I found out the hard way. I read the how to double DIN install thread but neglected to read the how to on installing an aftermarket deck in general in our SC's. I bought the Metra wiring harness adapter and didn't work. Follow the instructions on this thread on how to splice into the factory harness:
https://www.clublexus.com/forums/lex...b-working.html
Sorry for the crappy S2 phone pics, but here is my x950bh installed in my SC with the hybrid Metra/stock mounting method. Completed the install about a couple weeks ago, I'll need to pull it out again though to redo my parking brake bypass.
Attached Thumbnails Picks of Double Din Aftermarket Nav units installed-20130801_211145.jpg   Picks of Double Din Aftermarket Nav units installed-20130801_211340.jpg
Old 08-18-13, 06:30 PM
  #108
Qu0Cie
Qu0Cie's Avatar
Could i just use this?
http://www.crutchfield.com/p_1207081...s.html?tp=2977
Old 08-18-13, 06:57 PM
  #109
TimSC300
TimSC300's Avatar
Originally Posted by Emilio253
wow i wasnt even going to get an after market stereo cause i thought it would look weird but you guys proved me wrong these look amazing
Old 08-18-13, 07:28 PM
  #110
RicoLSX
RicoLSX's Avatar
In theory, by taking a quick look at it, maybe.
The five wires you splice to the plug coming out of your head unit are the same ones I cut off the factory harness (constant power, ignition, ground, remote on, dimmer probably). Then the remaining four are probably the four speaker channels for which you'd have to get a speaker wire to RCA female connector off your deck's harness to these four RCA's. There is another harness that I spliced into to get sub output from my deck to the factory sub amp, so you'd likely still have to splice for that and run a 18ga lead to that amp to have it power on.
I'm no expert, but that's just what I gathered by taking a quick look. The thread I linked above said it is hit and miss in using the aftermarket harness. I didn't want to chance it a second time plus I wanted to bypass the factory amp for the components (being that the deck already is) so I just spliced and ran the speaker leads to the rear LOL
Old 08-18-13, 08:26 PM
  #111
Qu0Cie
Qu0Cie's Avatar
Thanks. I'll probably buy it and see if it works, if not then I'll just slice and solder the wires.
Old 08-18-13, 08:34 PM
  #112
RicoLSX
RicoLSX's Avatar
Good stuff! Let us know if it works once you try it as it can save other members time if its a viable option. I'll be curious to see.
Old 08-19-13, 07:13 AM
  #113
Dx3
Dx3's Avatar
Old 08-19-13, 07:52 AM
  #114
tjmhillz
tjmhillz's Avatar
^^Nice thats the same exact double din i have and plan on installing.
Old 08-28-13, 03:47 PM
  #115
gotboost00
gotboost00's Avatar
Does anyone else here use a external interior amp and get engine noise?
Old 08-28-13, 07:33 PM
  #116
mikef
mikef's Avatar
here's mine. just need to go manual soon
Old 10-19-13, 12:49 AM
  #117
muhnkey
muhnkey's Avatar
Attachment 295884
Attachment 295885
Gahh I like your setup! So jelly atm...
Old 11-13-17, 08:57 PM
  #118
CoOl21
CoOl21's Avatar
Reviving this old thread...
Anyone put in an Android double Dins?
Old 11-14-17, 12:48 AM
  #119
- V -
- V -'s Avatar
i saw a video on youtube of a guy who just straight up put a nexus 7 android tablet in there...does that count? lol
Old 11-14-17, 09:44 AM
  #120
logix7
logix7's Avatar
getting ready to do a tablet in my car in spring. going to transfer the audio system from my last car. alpine type-r 6.5" comps front and back. and an RE XXX 15" for the trunk
Quick Reply: Picks of Double Din Aftermarket Nav units installed
