How bad are they? I did my first pegleg burnout in this car and I must say fun as hell with an open exhaust but I'm curious how bad is it and what parts receive the most torture? its only 200hp or so. Im assuming ofcourse the brakes, tranny and clutch and on a scale of 1 to 10 how bad is the strain on these parts? If it makes a difference, I have sway bars and strut bar with KYB GR'2. Thanks for any input. If I ever do another one I'll make a video for fun.
did a few when I first got the car (brake stand, same thing, right?), on a set of trash tires. did one in place for about 5 seconds. little later, did a running one for 10-15 feet, for about the same time.
got both tires smoking, so it's not as bad as a single tire smoke show. not doing any more until I get a lsd and manual trans (which will be a while).
It would be a 10 for sure! That is very bad on your bevel gears in the diff which are spinning at a very high rate of speed so not good at all
dually noted.
Originally Posted by Copilot
what is a pegleg burnout? Guessing its a burnout with an open diff?
its basically a brake stand still burnout, but with a manual trans.
So an LSD reduces the harm that burnouts cause? And single tire fires are really really bad? thats what mine did : (
Yup lsd will solve the problem if you must do a burn out and if it's an auto trans NEVER let the trans shift while doing a burnout as that will toast the 2nd sprag real quick.
lol I'm not to sure now. Although I will say this...Its only ever been burnout in ONCE. and it was by me.
One tire fire isn't any worse for the car than a burnout with a welded diff or lsd, except for the fact that one tire will obviously be more worn than the one not spinning.
If you understand how an open diff works then you would not have just made that comment.
