help, r154 shifter housing confusion
I bought a "soarer" r154 without the shifter housing. Then i bought a supra r154 shifter housing and rod from a different seller. When i line up the shifter housing on the tail of the transmission, the bolt holes do not line up how they should, they are a couple millimeters off.
you can see in the pic that the shifter rod is already there which confused me
my question is, what shifter housing do i need?
You have a tripod style trans? Hmmmm, I would think that the housing would have the same bolt pattern but apparently not. If they are really only a couple millimeters off, you may be able to mod the housing enough to fake it and make them fit.
If not, you may be forced to source a tripod style shifter which will be nearly impossible.
Are you positive you have a r154 and not an externally shifted W58?
gte & na-t
You should be able to modify the remote style shifter from an MK4 W58 and make it work the MK3 R154 shifter lever and housing will not work, i ran into that issue once before.
GL
GL
