SC- 1st Gen (1992-2000)
my sc400 1jz swap finally
Old 04-27-11, 05:47 AM
  #46
JDMCelsior
JDMCelsior's Avatar
Congrats on the build. You'll definetely have fun now.
Old 04-27-11, 07:05 AM
  #47
DoomLight
DoomLight's Avatar
dang i've been at my car for 2 months and you already have it running! grrrr
Old 04-27-11, 07:22 PM
  #48
mrae101
mrae101's Avatar
well I fixed my miss fire it was the spark plug gap. I regapped the spark plugs to 1.2mm and it now runs great so all I now have left is hooking up the exhaust and finish wiring the fans
Old 04-27-11, 07:33 PM
  #49
mrae101
mrae101's Avatar
I only have about $3500 in this and I can say for me it was easy. I did every thing on gas station pay if you do every thing your self you can save alot of money and gain alot of experience.
Old 04-27-11, 09:27 PM
  #50
xspsi6
xspsi6's Avatar
I plan on doing the 2jzgte swap in to my sc400 and I think I will do a step by step diy for the sc400 as there seems to be a lack of info in the sc400 swap dept I think.
Old 04-28-11, 06:25 AM
  #51
99SC42
99SC42's Avatar
I would replace that SC4 radiator with Sc300 one or maybe a supra TT radiator.
Old 05-30-11, 08:21 AM
  #52
lilpablo
lilpablo's Avatar
nice gonna do the 1j in mine but also gonna swap the tranny yea not much info in the wiring departtment
Old 12-20-11, 04:34 PM
  #53
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
How is the 1JZ holding up.. Can you enlighten me on the correct way to run the power steering lines? I cant find this info out anywhere!!!! I believe I have got it figured out but I want to be sure before I buy a custom made line the wrong length.
Old 12-21-11, 05:59 AM
  #54
DoomLight
DoomLight's Avatar
When i helped my friend do his SC400 to 1jz swap. I found him the SC300 power steering lines.
Old 12-21-11, 09:55 AM
  #55
zxfreak01
zxfreak01's Avatar
sweet it looks easy!! i almost didnt do the v160 swap because of all the info i read about how hard and how much and what not! but 3 hours later and walla!!! 2jzgte 6 speed iijjaaa ;-)
ps; it was a lready a 2jzgte with a 5 speed)
Old 07-17-12, 06:08 AM
  #56
SFrymyah
SFrymyah's Avatar
Originally Posted by account2x
Not accurate.
The difference in length is along the firewall in the engine bay. This means all the wires from the engine bay past the firewall need extending (with the exception of the heat VSV). The only wires that do not are the body plugs to the ECU.
The knock sensor wires can be extended past the shield although replacing the whole wire is more ideal
Extending the body plugs only will be fine. If you dont extend the ECU, it will hang behind the glove box.
Old 07-23-12, 01:27 AM
  #57
mrae101
mrae101's Avatar
It should be noted that all i extended was the body plugs which was simple and easy. ecu was moved to sit on top of the abs unit and the black kit panel was fitted back over the two. The car is now a big single and is running emange ultimate with pnp harness which give extra length and let me place the ecu in the oem location
Old 07-23-12, 05:18 AM
  #58
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
With this being said, how did you power the injectors and the coils? Did you have to run a jumper wire from the starter relay to the ignition under the steering?
Old 07-31-12, 02:07 AM
  #59
mrae101
mrae101's Avatar
powering the ignition was easy i hacked a plug off the 1uzfe. under the fuse box you will find two plugs. one plug is on your harness and the other is the wrong plug. you will be cutting the the right plug off the 1uzfe and will be using that. the plug from the 1uzfe has three wire's red orange and black and the black. the wrong plug only has two wires black and orange and black. all you need to do is soider the red and black wire and orange and black wire on the 1uzfe plug to the orange and black wire on the 1jz harness and black to black and plug it in. mine started first try
Old 07-31-12, 05:07 AM
  #60
99SC42
99SC42's Avatar
^^^ Yes that's another way of doing it! right ON. That's only issue when swapping the jz in the SC400.
Quick Reply: my sc400 1jz swap finally
