SC- 1st Gen (1992-2000)
Converting my corners into fogs...but how does the parts look like????
Old 02-16-11, 12:06 AM
jimmysc3
jimmysc3's Avatar
Default Converting my corners into fogs...but how does the parts look like????
I want to convert my corners to fogs. I got the30 amp fuse and inline fuse holder already. As far as the t-taps, pin amp automotive relay and connectors, i'm not sure of which ones to get because there are different types and varieties. Can someone post any pics of how they look like? I want to make sure i get the right parts. I got this info on Intellexual.Net and says i can find them at radioshack.
Old 02-16-11, 12:23 AM
fliptrix
fliptrix's Avatar
the auto relay: http://www.radioshack.com/product/in...ductId=2062477
t-taps:
connectors, you could use these kind to hook it up to the relay, or just not get any connectors and solder them to the relay:
Old 02-16-11, 12:27 AM
Yesterday
Yesterday's Avatar
I just did mine today. All I did was cut both the wires leading from cornering light, cut both wires from side markers. then twist all colored wires together, solder, tape. Twist all white wires together, solder tape. Done.
If u don't have solder just buy some crimps. I had all the tools to do it for free
Old 02-16-11, 12:41 AM
jimmysc3
jimmysc3's Avatar
ahh sweet! Thanks for posting the pics. I think i'll go to kragen for the t-taps and connectors. I don't remember seeing them at radioshack after an hour of reading labels and looking
Old 02-16-11, 12:47 AM
jimmysc3
jimmysc3's Avatar
So do you really need the amp fuse, inline fuse holder and relay? If its just cutting through the city/parking light wires and connecting them to the corner lights, i can easily do that. I just thought you'll need al the parts listed on Intellexual.Net for it to function correctly.
Old 02-16-11, 09:04 AM
Candela
Candela's Avatar
since its a 15w bulb/harness you can just simply wire it into your parking lights, which are also 15w bulbs/harnesses
paulrichmo
06-29-15 07:19 PM
mshumack
RX - 3rd Gen (2010-2015)
04-29-15 06:44 AM
minh2015
05-06-13 06:16 AM
Sup2jzgte
Lighting
05-01-09 07:49 AM
Aristo94
01-30-07 11:45 PM
Quick Reply: Converting my corners into fogs...but how does the parts look like????
