SC- 1st Gen (1992-2000)
red fluid leaking
Old 02-02-11, 05:36 PM
scottinky
scottinky's Avatar
Default red fluid leaking
ugh. red fluid under neath my recent purchase. more towards the right center of the engine. I'm thinking transmission fluid. car drives and shifts
fine. anyone care to diagnose?
Old 02-02-11, 06:06 PM
SChema
SChema's Avatar
Sounds like a power steering leak; check the hoses, rack and pump.
Old 02-02-11, 06:07 PM
1WILLY1
1WILLY1's Avatar
either tranny fluid or power steering ---i really dont think it can be anything else---forgive me if im wrong.
Have u been checking your tranny fluid level?
U can narrow it down right there.
Old 02-02-11, 06:16 PM
SexyLexy
SexyLexy's Avatar
Depending on the color of your coolant it could be coolant... Did you get under the car with a flashlight and take a look around?
Old 02-02-11, 06:35 PM
good2go
good2go's Avatar
Next time you might want to mention your car's year and model: 92 SC400
Old 02-03-11, 03:03 AM
scottinky
scottinky's Avatar
i haven't checked the tranny fluid. the puddle only appears after driving. I filled the coolant reservoir with green antifreeze. I'm taking it to be checked out tomorrow morning. power steering pump would be cheaper than tranny to fix.
Old 02-03-11, 03:14 PM
1WILLY1
1WILLY1's Avatar
more than likely it would not be a tranny problem but a line problem of sort.
My tranny actually leaks a very little amount of fluid through one of the lines, its not that big of a deal as long as u keep an eye on your leveels from time to time.
Old 02-03-11, 03:38 PM
Bl0b
Bl0b's Avatar
Probably tranny fluid. If it's your PS pump, I had one poop out on me about a year ago in my old SC. Don't remember the exact price but I know they wanted over $700 at a local shop to repair it. Ended up doing it myself.
Old 02-03-11, 03:50 PM
bryan767
bryan767's Avatar
does it smell like B.O. (body odor)? if so its your tranny
Old 02-03-11, 05:43 PM
solpowerr
solpowerr's Avatar
I had a problem like that about a month ago. It turned out to be the high pressure fan oil line. Check the fan oil level and check the two lines that go to the fan. Mine actually was leaking so bad it froze up thehydralic fan clutch and snapped the serpentine belt. Get it checked out asap.
Old 02-04-11, 06:24 AM
scottinky
scottinky's Avatar
car is at the shop this am. I'll know soon what it may be. I am not that mechanically inclined, but I guess now would be a good time to learn.
Old 02-04-11, 06:47 AM
ThomasGS4
ThomasGS4's Avatar
Most likely power steering since the car shifts fine, and the power steering calls for auto transmission fluid anyway. Maybe it overflowed? Pics?
Old 02-04-11, 07:11 AM
scottinky
scottinky's Avatar
well, its the transmission pan and gasket. $170 to fix it.
Old 02-04-11, 08:14 AM
FatBrian81
FatBrian81's Avatar
You are getting out fairly cheap compared to a power steering pump. Does that price include a fluid and filter change ? You might as well do it while they're in there.
Old 02-04-11, 08:52 AM
good2go
good2go's Avatar
If it's not too bad, you could always just let it go; $170 buys a LOT of tranny fluid.
(Or DIY)
Quick Reply: red fluid leaking
