SC- 1st Gen (1992-2000)
Whats the correct way to install a FRONT MAIN SEAL?
Old 02-01-11, 07:12 PM
6SOARER
6SOARER's Avatar
Default Whats the correct way to install a FRONT MAIN SEAL?
How do you get that Front Main Seal seated right? What do you use to get it in?
Obviously I did it wrong cause I had oil pouring out under the Crankpulley while the car was running.
Old 02-01-11, 10:44 PM
navazsc3
navazsc3's Avatar
Man I use a big socket and just push it all in equally
Old 02-01-11, 10:48 PM
soarer13oy
soarer13oy's Avatar
Put lube on the seal and do what navazsc3 said.
Old 02-01-11, 11:04 PM
chingpo05
chingpo05's Avatar
dont put lube on the seal bc it will leak. use hand soap diluted with water if you need to ( you shouldnt) and tap it in equally with a socket. the reason you should use soap and water is bc once it drys the seal will (seal) it you use oil it will leak again
Old 02-02-11, 01:14 PM
topdog849
topdog849's Avatar
make sure to replace your pcv valve or else if it is clogged you will just blow your front and rear main seals.
Old 02-02-11, 02:13 PM
SC51
SC51's Avatar
God I just went through the same B S with mine, you just have to be very careful because the slightest dent in it it will leak so don't tap to hard.
First off the correct way if you dont have a deep *** socket would be to purchase a seal press kit, but if not,
Make sure everything is kinda warm(I used hairdryer), if its cold out it will be harder. Put some oil on the inside of the gasket that goes over crankshaft, and if u must you can add a little rtv to the outside to help slide it in.
Use the old gasket to put over the new one to tap on with a socket extention, just dont do it too hard. I usually get the bottom in first and work your way around.
Old 02-02-11, 05:40 PM
good2go
good2go's Avatar
If you don't have a properly sized socket, many times a seal can be installed by tapping in using a short piece of pipe (pvc, abs, etc.) or pipe fittings (coupling, reducer, etc.) with a nice square cut on the end and then sanded smooth (no jagged end against the seal). This can be useful too, as you can gauge whether you are driving it in straight by looking at how perpendicular the pipe section is in relation to the block.
PanicUnit
Performance & Maintenance
50
09-16-23 05:06 PM
Jvgs300
05-11-17 01:33 PM
gkcar52
05-07-17 04:54 PM
AROD
Performance
03-08-03 11:20 PM
Quick Reply: Whats the correct way to install a FRONT MAIN SEAL?
