SC- 1st Gen (1992-2000)
Favor (99 SC400) fuse/relay picture
Old 01-23-11, 02:39 PM
masagsxr
masagsxr's Avatar
Default Favor (99 SC400) fuse/relay picture
Could someone please take a picture of their fuse/relay box under the hood as well as the guide chart on the cover.
Post here or please email me high resolution picture so that I can take a better look..... Long story but the cover on mine might have been different.
Thanks,
MarkAncheta@hotmail.com
Old 01-23-11, 10:41 PM
masagsxr
masagsxr's Avatar
nobody with 99 sc4 maybe sc3 that could post pix?
Old 01-24-11, 07:48 PM
Durrby
Durrby's Avatar
Not the greatest pics and it's dark out but it should help...from my 99 SC400
The pic is rotated the correct right way but keeps uploading this way.
Old 01-24-11, 10:37 PM
masagsxr
masagsxr's Avatar
Thanks... I appreciate it a lot... Someone sent me a 98 one and the only difference was he had the dimmer on his. Weird ours didn't need that.... We have the exact same setup.
Now to continue researching on my initial problem. My DRL/High beam / Flasher completely stopped working out of nowhere. No idea why... The problem before that was, after turning off the car the DRL would turn back on. I didn't even know about it until my brother told me. Thought I fixed that but it turns out that I guess the DRL/Highbeam/Flasher just completely broke and stop working. No response to the combo switch. Bulbs are ok, Fuse are ok. No power going through the harness. I think the switch is ok tho because the lowbeams comes ON when I flash (pull) the combo switch but the blue highbeam indicator doesn't turn on. ....... Running out of ideas unless I take it apart and test the switch itself and the harness from under the dash.
Old 01-24-11, 10:54 PM
masagsxr
masagsxr's Avatar
Ok... I think my car is haunted.. Was chillin' in my room and bro told me the lights are ON again (by itself, car is off, no key). Flashed the highbeam then as soon as I let it go, the highbeam turned off (ok, thats a good thing). Now I try to start the car and the DRL is still completely off and wont turn on.... I hope it does not turn ON again by itself in the middle of the night and drain the battery while i'm asleep.
Old 01-26-11, 02:53 PM
masagsxr
masagsxr's Avatar
just an FYI... found the culprit to my problem.. DRL Relay #3 is bad (82841-24010). I suppose initially it was shorting out which is why my DRL stays ON. Now it looks like its completely broken.
$120 at local dealer special order. Getting it on fleebay for $40 unless there are a few good men out there with parts collecting dust in their garage they'd like to give/sell .
aizen
08-17-19 01:35 PM
dirkdiggle
Maintenance
01-21-09 05:07 AM
du3nmd
RX - 1st Gen (1999-2003)
09-12-05 06:39 PM
Quick Reply: Favor (99 SC400) fuse/relay picture
