SC- 1st Gen (1992-2000)
Sc400 Steering Wheel
Old 01-06-11, 10:05 PM
CoryJNason
CoryJNason's Avatar
Default Sc400 Steering Wheel
I have recently bought a 92 sc400. I believe it has the LS400 steering wheel though. The airbag light is on. The fog lights only work when I use the directional, and the cruise control doesnt work. Will all this go away if i swap back to an original sc400 steering wheel? Or will the cruise control atleast work?!? Please help!
Old 01-06-11, 10:08 PM
N00bie909
N00bie909's Avatar
no that is an scxxx steering wheel they didnt change to 3 spoke till 98 and as for your "fog" lights they arent really fogs they are blinkers to turn. fogs are in 95+ scs welcome to the forums.
Old 01-06-11, 10:42 PM
CoryJNason
CoryJNason's Avatar
okay, so when I press the buttons on the wheel(like function, mode and what not) it turns on the cruise control and if I press one of the buttons again it turns them off. The cruise control stick doesnt work when I try to use it though. How do I get 95 fog lights to fit?
Old 01-06-11, 10:44 PM
-Samurai-
-Samurai-'s Avatar
You'd be better off doing the DIY making your current "cornering lights" into fog lights.
Old 01-06-11, 10:56 PM
CoryJNason
CoryJNason's Avatar
do you know of any threads that have pictures? both write-ups are kinda fuzzy to read... any ideas on cruise control problem?
Old 01-06-11, 11:30 PM
shawnlexus
shawnlexus's Avatar
is your brake light on?
Old 01-07-11, 07:47 AM
Candela
Candela's Avatar
Maybe you're not sure how to use the cruise control? Turn it on, then set, then let go of gas, otherwise it sounds like the main cruise module is stuck. 95 foglights dont fit on 92-94 bumpers, just follow the write up.
Old 01-07-11, 07:53 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
PM a member on here named SChema about the cornering lights. He did mine for me and he should be able to point you in the right direction.
As for the cruise control, I've never used it before. I don't even know how to use it to be honest.
Old 01-07-11, 09:29 PM
CoryJNason
CoryJNason's Avatar
yes i know how to use cruise control. The entire stem doesnt work(set, cancel, excel, accel). No the Brake light is not on.
Old 01-08-11, 12:00 AM
shawnlexus
shawnlexus's Avatar
check your brake fluid level
Old 01-08-11, 12:13 AM
OaklandLex
OaklandLex's Avatar
Why would you want cruise control? This car is insanely fun to drive!
Old 01-08-11, 02:32 PM
CrazySC300
CrazySC300's Avatar
"...The fog lights only work when I use the directional..."
LMFAO! Another '92-'94 owner who thinks that their SC is equipped with foglights
But yeah, There's a DIY write up around here to help turn your cornering lights into "faux" foglights...just search, you'll find it.
Old 01-08-11, 09:17 PM
CoryJNason
CoryJNason's Avatar
why wouldnt I think there were foglights? There are big lights underneath the headlights that look identical to them. Sorry I havnt spent countless hours researching every aspect of the car as I have a thing called a life and job.
Old 01-09-11, 12:00 AM
CrazySC300
CrazySC300's Avatar
No, they're not totally identical, Look closely at your bumper and look at one from an actual '95-'96 model and you'll see that they're very much different...very subtle but different nonetheless. The differences are that the foglights on the '95-'96 bumpers have a line going across 'em and are actual functioning foglights which can be switched on and off at will (via foglight switch [See enclosed pic]) and are also slightly shaped differently than the cornering lights on the '92-'94 bumpers, another un-noticeable and subtle difference is the lower front fascia (Underneath the front license plate)...On your front bumper, you may notice a large line going across it...On the '95-'96 bumper, it's just a black plastic lower grill....Oh! And all '95+ year models have glass high beams too FYI.
Here are some pics of a '95-'96 bumper for reference if you do not believe me...
And if you still insist that your SC was equipped with foglights, Then let us know if you find this foglight switch on your instrument wand...
Old 01-09-11, 08:30 AM
ScLostinPA
ScLostinPA's Avatar
i swear this guy is infatuated with SC fog lights , stop jacking peoples threads and calling them out on stupid **** noone mentioned , we understand i promise , find a new topic to troll
Quick Reply: Sc400 Steering Wheel
