SC- 1st Gen (1992-2000)
Amp mounted to gas tank...?
Old 12-17-10, 07:29 AM
aporozco
aporozco's Avatar
Default Amp mounted to gas tank...?
I need to find somewhere to mount my 5-channel amp. It's a kicker zx700.5 which is kinda big at 9"x16". If I put it on a piece of plywood, and liquid nailed it to the gas tank, would that be safe/logical? Anyone have any other ideas? Thanks
Old 12-17-10, 07:43 AM
Kira X
美少女戦士セーラームーン
Forum Moderator
Kira X's Avatar
That may not be a bad idea. I know those Kicker amps are pretty big, but is have you tried looking at building an amp rack on top of the gas tank? It's possible that it may be too big though.
Old 12-17-10, 07:49 AM
sc3tech
sc3tech's Avatar
i wouldnt do that. just find another place to mount that thing
Old 12-17-10, 10:02 AM
LEX_MAN
LEX_MAN's Avatar
yeah, i'd stay away from the gas tank.
Old 12-17-10, 10:56 AM
ishootstuf
ishootstuf's Avatar
I don't see anything wrong with that. Anyone see the Mythbusters where they shoot through the gas tank and it won't ignite? As long as it's on plywood and glued, why not?
Old 12-17-10, 11:00 AM
LEX_MAN
LEX_MAN's Avatar
"Glued to the gas tank" thats already sounds ghetto! XD
Old 12-17-10, 11:05 AM
YeA 2jZ
YeA 2jZ's Avatar
I saw the episode, LoL makes explosive movies scenes a whole lot different for me. But i have the same idea i am just going to ahve the anchore points for the wood from the bottom of the trunk and top area near the speakers
Old 12-17-10, 11:13 AM
IXI187IXI
IXI187IXI's Avatar
im sure you can find a better place. i wouldnt even think of mounting it there
Old 12-17-10, 01:01 PM
OaklandLex
OaklandLex's Avatar
Not a good look. Amps get hot after using them for a while
Old 12-17-10, 01:50 PM
stockhatch
stockhatch's Avatar
Is there even anywhere flat on the tank to be able "glue" to? It wouldn't cause any kind of issue afaik, but why not mount the amp to the sub enclosure?
Old 12-17-10, 02:06 PM
Kira X
美少女戦士セーラームーン
Forum Moderator
Kira X's Avatar
Unhappy
Actually, I don't think there is a flat surface on the tank either...
An amp rack might work though.
Old 12-17-10, 02:48 PM
d1trainee
d1trainee's Avatar
Don't do it.
Old 12-17-10, 03:06 PM
HEWJsc4
HEWJsc4's Avatar
On my old SC I installed a plank of mdf that was suspended from brackets attached to the car using the holes underneath where the rear speakers are. It cleared the gas tank by an inch or so. I installed two amps onto the MDF board. This is with the stock sub removed. I did not want anything resting on the gas tank.
Old 12-17-10, 07:26 PM
ucmysc400
ucmysc400's Avatar
Dont do it on the gas tank find another spot.
Old 12-18-10, 07:05 AM
lfrers
lfrers's Avatar
If your amp is going to be bumpen for any real amount of time you want that thing to get some air so it wont overheat.
I got an Alpine mono for the sub, ,mounted it to a thin piece of plywood, cut out a section in the Gas tank cover and mounted it flush. Hides all the wires and the heat fins are exposed in the trunk. Worked well for me.
Quick Reply: Amp mounted to gas tank...?
