SC- 1st Gen (1992-2000)
can i bypass my heater control valve
Old 12-15-10, 01:18 PM
americk22
americk22's Avatar
Default can i bypass my heater control valve
my heater control valve is leaking fluid. can I just delete this and connect the two hoses together? has anyone done this?
Old 12-15-10, 01:30 PM
scviolence
scviolence's Avatar
u can bypass it but eventually u will pay for it....lexus didnt put it there for no reason...
Old 12-15-10, 01:34 PM
americk22
americk22's Avatar
what would be the consequences ? other than no heat which i dont need in FL?
Old 12-15-10, 01:54 PM
tavarish
tavarish's Avatar
lol... Bypassing the heater control valve is a common work-a-round for the SC. Just remember to bypass the heater core in the summer or your AC wont work.
Old 12-15-10, 02:01 PM
americk22
americk22's Avatar
how hard is it to by pass the heater core^^? Am i just better off buying the heater control valve for $200?
Old 12-15-10, 03:06 PM
Klaus
Klaus's Avatar
https://www.clublexus.com/forums/per...rol-valve.html
A search for bypass heater control valve yielded a lot of results
Old 12-15-10, 05:17 PM
scviolence
scviolence's Avatar
u can get one from aliga for 60 bucks and yes your heat will still work...it was 32* outside yesterday and my car was a nice toasty lil oven and i have it bypassed lol...
Old 12-15-10, 05:27 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Not needed in FL. Chunk it.
It's a device that turns your hot antifreeze through your core and vents when you need it and you live in florida...........so......... yeah.
Old 12-15-10, 07:19 PM
scviolence
scviolence's Avatar
it was 34 degrees in florida keep it...
Old 12-15-10, 07:22 PM
ucmysc400
ucmysc400's Avatar
yea u can i did it to my car
Old 12-15-10, 07:27 PM
CrazySC300
CrazySC300's Avatar
Just replace it, They're easy to obtain and easy to replace and you can get 'em at a local junkyard for about $50 like I did...and who knows? You might end up selling the car to someone else in the future, hence the need to replace the heater control valve.
Old 12-16-10, 11:48 AM
americk22
americk22's Avatar
i want to by pass it but the question is will my cold ac still work? if not then forget it lol
Old 12-16-10, 02:56 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
After that question I'm gonna advise you don't touch it at all.
Old 12-17-10, 05:15 PM
ogre
ogre's Avatar
correct me if im wrong, but dont they just run off of vaccuum? if they do just go walkin around a junkyard and buy one off of something else. i ditched mine when i went single, i wouldve given you mine
Old 06-17-14, 08:51 AM
fstlane
fstlane's Avatar
Sorry to bring up a really, really old thread, but I found it searching and has pretty much answered my question, except for one. Also, this is on a 94 GS 300, but for the most part it should be the same correct?
O.L.T you mentioned that you can just do away with the heater control valve if one wants to do so. Well I do, I live in south FL, and I have owned my GS almost 7 years, and have never once touched the heat on it. Never. But, the A/C does work perfect, and I use it on a daily basis.
The main reason I am posting is the rear hose going from the head to the HCV (Heater Conrol Valve) burst again on me today, and I currently have it bypassing the HCV as the plastic fitting on the HCV broke as well, while we were trying to fix the hose. SO, with that said, I just want to do away with it completely.
First off, do you really have have to do something to the heater core to keep the a/c working, and if so what? I turned the A/C off on my drive in to work after fixing it this morning and have not driven the car again since, so I do not know if the current configuration has effected the A/C yet.
Any help would be greatly appreciated.
Thank you,
-Bryan
Quick Reply: can i bypass my heater control valve
