SC- 1st Gen (1992-2000)
Brakes!!! HELP!!
Old 11-27-10, 11:05 AM
NEbiker10
NEbiker10's Avatar
Default Brakes!!! HELP!!
Hey Guys..I need new brakes bad...the rotors are warped like
Any Suggestions...I dont want a big brake kit and I would like to keep it under 300 bucks...and I really dont wanna waste my time with cheap chinesse drilled stuff.
At the Local Advanced Auto I priced it out for 4 new rotors and Semi Metallic Pads for 231.00
Old 11-27-10, 12:15 PM
SChema
SChema's Avatar
Those will work, use blanks and a good st of pads, you'll be just fine.
Old 11-27-10, 06:02 PM
sc3tech
sc3tech's Avatar
how do you know theyre warped? did you measure for minimum thickness and runout?
Old 11-27-10, 07:58 PM
NEbiker10
NEbiker10's Avatar
When you press the break they pulsate...I dont have time to measure thickness...just gonna new everything
Old 11-27-10, 08:04 PM
pieisgude
pieisgude's Avatar
I'm in the same boat as you. Mine are warped. I can feel the pulsations when the pedal is pressed. But my mindset is, why just replace/fix the things that are broken, upgrade them.
Old 11-27-10, 09:02 PM
NEbiker10
NEbiker10's Avatar
What would be a good upgrade. any recommendations? Only big brake kits I see are 1500+
Old 11-27-10, 09:12 PM
6SOARER
6SOARER's Avatar
LS400 or MKIV Supra BBK without breaking the bank
Old 11-28-10, 11:19 AM
sc3tech
sc3tech's Avatar
id look for the mkIV also. easy and cheaper upgrade
Old 11-28-10, 11:23 AM
1SICSC4
1SICSC4's Avatar
That's still at least $450 for new pads, rotors, calipers, and hardware.
Old 11-28-10, 06:30 PM
pieisgude
pieisgude's Avatar
LS400 is what i'm hoping to do. Search around, get it used. Look at a local junkyard. And definitely check the f/s forum.
calipers and pads...
Old 11-28-10, 07:50 PM
lfrers
lfrers's Avatar
Just buy some Ebay front rotors and be done with it. Cheap & easy.
Old 11-28-10, 08:58 PM
4thHorsemn
4thHorsemn's Avatar
Im on the ls400 and they stop on a dime!!!!
Old 11-29-10, 03:33 AM
imDementeD
imDementeD's Avatar
i used napa rotors for about 30 bucks a piece and then bought some ultimate axis brake pads for under 70 shipped (just fronts) ..they are pretty loud tho
Old 11-29-10, 11:45 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Make sure they will clear your current rims if you are on anything aftermarket. Just a thought.
Old 11-29-10, 11:59 AM
vwynn
vwynn's Avatar
which is perdy dam cheap for cheap insurance.
nothing wrong with spending "tooo" much on brakes... its the thing keeping you from hitting the other car or anything else...
TT Brakes FTMFWWWWWWW
Quick Reply: Brakes!!! HELP!!
