SC- 1st Gen (1992-2000)
92-94 sc cornering light DIY.. Rough draft Feedback?
Old 11-24-10, 02:42 PM
Emilio253
Emilio253's Avatar
Default 92-94 sc cornering light DIY.. Rough draft Feedback?
Items needed:
SPLICE
http://www.oreillyauto.com/site/c/de...keyword=splice
WIRE
http://www.oreillyauto.com/site/c/de...1963&ppt=C0335
PLIERS
KNIFE OR SCISSORS
JACK
SCREWDRIVER
10" SOCKET ( I think it is a 10")
Take two pieces of wire that is long enough to get from your side marker to your cornering light.
Then you crimp the light blue splicing piece on both ends of the wire.
Do this before you start, it will make things faster.
then Jack up the car, which is not needed, but make things easier..
First you need to take off the black mud guard that is in front of your wheel and behind your side marker.
( it has about ten screws )
Second splice your dark blue splicer into your red/white wire that is connected to your side marker. Then connect the light blue piece ( that is connected to one end of your wire) to the dark blue splice.
Third go to your cornering light and splice the dark blue splicer piece to the green/white wire. Then connect the other light blue piece into the dark blue splicer.
( MAKE SURE THAT THE COPPER IS SHOWING WHEN YOU SPLICE INTO THE WIRE. SO IT WILL GET A GOOD CONNECTION. IF YOU DON'T, THEN IT WILL HAVE A BAD CONNECTION AND FLICKER ON AND OFF. wHICH IS WHY i INCLUDED SCISSORS OR A KNIFE IN THINGS NEEDED.)
fourth cut the red/white wire right behind the splice for the cornering light, so when you turn on your turn signal it's not getting too much power.
fifth now try to turn on your side marker, then your lights. ( if all is good, then move the wire around to see if you have a good connection.
sixth, repeat on your opposite side.
ask away if you have any questions
Old 11-24-10, 03:19 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
It looks good so far. I had a friend do mine a while back.
Old 11-24-10, 06:18 PM
OaklandLex
OaklandLex's Avatar
I want to do this but w/yellow fogs
Old 11-25-10, 01:55 AM
CrazySC300
CrazySC300's Avatar
Nice, Now let's see you '92-'94 guys do an HID retrofit on these "Cornering" lights.
Old 11-25-10, 09:36 AM
nivek5sfe
nivek5sfe's Avatar
im going to try to come up with something like turbodreamz did
i need me some fogs
Old 11-25-10, 05:53 PM
ucmysc400
ucmysc400's Avatar
I wanna get HIDS too.. but thanks !
Old 11-26-10, 06:12 AM
Luv2xl
Luv2xl's Avatar
Question to the OP: What happens if you don't cut that red/white wire?
Old 11-27-10, 09:58 AM
Han7
Han7's Avatar
just did this a week ago
Old 11-27-10, 09:56 PM
Emilio253
Emilio253's Avatar
If you don't cut the red/white wire, then when you turn on your turn signal, then your cornering light is getting twice the power..
power from the signal and power from the side marker.. this might blow your bulb with too much power, so cutting the wire makes it have a steady current at all times.
Old 11-27-10, 10:02 PM
Emilio253
Emilio253's Avatar
Hey Han, I like your set up! I see you live in washington, where do you live at in washington?
Your crazy for driving your sc in the snow man lol
Old 11-28-10, 09:25 AM
nivek5sfe
nivek5sfe's Avatar
details please?
Old 10-24-11, 10:48 PM
zacknguyen
zacknguyen's Avatar
Hi ... Emilio. Would you tell me briefly. How did u put HID into your cornering light? What type bulb? Does it need modification?
I also live in WA, in Federal Way area of Seattle. If u dont mind i can swing by your place to learn more.
Old 10-24-11, 11:47 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Looks pretty good so far. Nicely done!
Old 10-25-11, 09:50 AM
Emilio253
Emilio253's Avatar
It's actually not an HID bulb.. I was just using the stock corner light bulb. I wired them up so they would stay on while the side markers were on.. If you need any help I would love to help you do it.. It's cheap, easy and a cool looking mod.
Thank you!
Old 10-25-11, 09:52 AM
turbodremz
turbodremz's Avatar
Been there done that, worked and looked excellent
i need me some fogs
Let me know if you need any help. Just look for the Blazer brand fog lights on ebay. They are kind of hard to find, but well worth it
Quick Reply: 92-94 sc cornering light DIY.. Rough draft Feedback?
