SC- 1st Gen (1992-2000)
How to remove scratches from tail lights
Old 11-13-10, 02:30 PM
jdmsfl305
jdmsfl305's Avatar
Default How to remove scratches from tail lights
I came across a decent set of 97 tail lights but they have some scratches. i no how to do the whole wet sand method for the headlights. The only problem is the lens on the 97 tails are clear so the reflector isnt right behind the lens so i dont want to sand it and see any hair line scratches when im done. Any recommendations on what grid sand paper to use.
Old 11-13-10, 03:02 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
2000 grit and you should be fine. I wouldnt go any further down past 1500 on those plastic outer covers. I just did mine and they look beautiful.
Old 11-13-10, 03:10 PM
turbodremz
turbodremz's Avatar
^^^that sounds about right. 2k grit wet-sand, then polish and you should be fine.
Old 11-13-10, 03:35 PM
jdmsfl305
jdmsfl305's Avatar
I went to my local advance auto parts and the highest girt sand paper i saw was 1000. Were can i buy 2000 girt sand paper i also check home depot and there highest was 600.
Old 11-13-10, 03:43 PM
Bender25
Bender25's Avatar
Walmart carries it
Old 11-13-10, 09:48 PM
ArodDaLob
ArodDaLob's Avatar
wetsand using 2k grit sandpaper, use scratch-x to buff it out, and you're done. should take no more than 30min
Old 11-14-10, 07:58 AM
jdmsfl305
jdmsfl305's Avatar
Great! Thanks for all the help guys.
eknine9
13
05-04-16 03:48 PM
lexusben
01-02-12 02:57 PM
durtysc300
07-07-07 07:09 PM
nimit1234
06-05-06 05:22 AM
Losiho
Automotive Care & Detailing
04-04-03 08:58 AM
Quick Reply: How to remove scratches from tail lights
