SC- 1st Gen (1992-2000)
19x9.5(f) & 19x10.5 (r) perfect fit....
Old 07-30-02, 12:58 AM
C to the O
C to the O's Avatar
dayam...
that is one clean ride... i'm sure you have alot of heads turning when you're out cruisin...
just curious though, why'd you drop to nineteen's after the dubs?
Old 07-30-02, 04:14 AM
Sc400on20s
Sc400on20s's Avatar
The 20"s didn't fit right and back then I was into the Dubs hype but now I think that 19"s with the kit looks perfect and the ride is so+++ much better!
Hey Do-Luck Sc,
I think that any performance shop will tell you the norm or the safe route but the boys at EuroSport go to the extreme(in my opinion), I have some crazy pics of the ***** they do, it's pretty impresive (totally japanish)
Here's a sample....guess what car...
Old 07-30-02, 07:15 AM
howiedoit
howiedoit's Avatar
I think it's the other way...under 38...because aren't supra wheels supposed to be in the 40's? not sure...ain't no wheel pro
Originally posted by do-luck sc
that's weird... it was to my understanding that with anything over +38 offset, it would rub the suspension....
could anyone clarify?
Old 07-30-02, 07:23 AM
Slick Lex Coupe
Slick Lex Coupe's Avatar
Is that a Vitz?
Old 07-30-02, 09:58 AM
Richie
Richie's Avatar
That is a Toyota Yaris, at least that's what they call it here.
Looks pretty nice.
Old 07-30-02, 11:14 AM
SoCalSC4
SoCalSC4's Avatar
The fronts fit because the tire is stretched so far on the rim. If you used a proper 275/30-19 (technically what a 19x9.5 would be used for), the tire would contact the suspension upright.
The rim clears because it is at a smaller radius from the hub centerline, and the upright is curved away from the wheel at this point. BTW, a higher numeric offset moves the wheel inboard, a lower numeric offset moves the wheel outboard.
Overall, the car looks sharp! Congratulations!
Old 07-30-02, 11:18 AM
AutoCoutureSC
AutoCoutureSC's Avatar
Post
socal,
so techically speaking, a 19x9 would be the widest in the front? with a 265-35-19 tire?
Old 07-30-02, 11:56 AM
daygo718
daygo718's Avatar
Awesome car! I can't get enough of the Auto Couture kit on the SC's. Great wheel choice...nice phat lip!
Old 07-30-02, 05:24 PM
Sc400on20s
Sc400on20s's Avatar
believe it or not it's a Toyota Echo with a RS front conversion direct from Japan!!
Pretty sweet huh.
:eek: :eek: :eek:
Old 07-31-02, 01:48 AM
Deceptik1
Deceptik1's Avatar
Sweet car! I wouldn't mind rollin in a a vitz hatchback if they ever brought it here. Too bad those echos are hideous stock. Great gas savers though.
Old 08-01-02, 05:58 PM
g_lex_6
g_lex_6's Avatar
man that is one clean sc. i ordered a particular setup except i am going to run 19x8.5 up front with 235/35/19. for the rear i am going to run 19x10. but my question is what is the maximum width that i can run without the tires rubbing? my rear fenders are not rolled. what's yalls opinions?
Old 08-14-02, 01:55 PM
AutoCoutureSC
Post
g_lex,
did you order the Gettins? what offset did you get for the front and rear?
Old 08-14-02, 02:52 PM
moshlub
moshlub's Avatar
DAYEM!!! Those are kick-a$$ pics! (I mean wheels ... and bodykit) Post more. BTW, are those wheels available in chrome and gold trim?
I've always wanted the AutoCouture kit and the Manaray VR-5 Quest wheels. But those wheels aren't available anymore. Judging from the looks of yours, I might have to consider them.
Old 08-14-02, 03:19 PM
808state
808state's Avatar
a little too extreme for me but cool...
did you say echo... put that pic up next to the sup'd up tercel and paseo.
btw, stay out of waiks and downtown with your safety sticker bracket the way it is (doesn't look like you can see it straight on from the rear).
hope you got your affidavit for the aftermarket parts from eurosport for your reconn. even if you can get a safety inspection without your reconn, i'd suggest you get the affidavit anyway just in case...
last time (last year) i went to eurosport, they didn't want to install anything on a lexus car (unless it was an is300)..but they'll sell you the parts though and pad their profit margin. so much for one stop shopping.
Old 08-14-02, 06:24 PM
SC300T
SC300T's Avatar
Love the wheels... Do they come in a more conservative 18x8.5 or 18x9 and 18x10?
Quick Reply: 19x9.5(f) & 19x10.5 (r) perfect fit....
