SC- 1st Gen (1992-2000)
Finally doing something about the "silent" lock in the 92-94 SC
Old 09-22-10, 10:04 PM
Klaus
Klaus's Avatar
Default Finally doing something about the "silent" lock in the 92-94 SC
So just ordered this:
http://www.kptechnologies.com/products.php#/9
Based on the diagram they provide there's no reason why it shouldn't work.
Looking at this:
http://www.lextreme.com/ls90.pdf
I can probably assume I'll find similar wiring in the SC, just need to look into it. The device is simple, it just uses the lock, unlock, ignition, and 12v wires.
I'd love to figure out how to wire this into the parking lights as well, but it says it needs a relay. It outputs a 200mA signal, just not sure what relay to match up with this to fire the parking lights. Ideas?
Either way getting that nice lexus beep when I lock and double beep when I unlock will be nice- I hate guessing.
Old 09-22-10, 11:27 PM
scENFORCER
scENFORCER's Avatar
I was unsure whether the 99's did or not when I flew down south to buy it. And it did! Nice little modern touch that I love!
Good luck with the mod!
Old 09-22-10, 11:43 PM
ClearP
ClearP's Avatar
get an aftermarket alarm, problem solved
Old 09-22-10, 11:45 PM
CrazySC300
CrazySC300's Avatar
Wow! I never knew that '92-'94 SC's didn't have that audible beep sound...In an ironic twist, '92-'94 SC's have an audible beeping sound on their climate controls, yet the '95-'00 year model SC's don't?
Old 09-23-10, 01:42 AM
kwg
kwg's Avatar
seriously. 2way paging w/ auto start
Old 09-23-10, 05:23 AM
SH_JZZ30
SH_JZZ30's Avatar
+1 my corner lights, bumper lights, city lights, and fog lights all flash when I arm or disarm my alarm along with a single chirp for lock and triple chirp for unlock.
And with the remote start, all of the above lights turn on.
Old 09-23-10, 06:02 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
I plan on getting a 2-way pager with remote start. I hate that my 93 SC doesn't make a sound when I arm the alarm.
Old 09-23-10, 07:17 AM
Klaus
Klaus's Avatar
That's all good and well but i'm trying to keep the car as OEM styled as possible. Even if I got an aftermarket alarm I would pick up this unit for the clean OEM style lexus sound rather than the annoying chirp that comes on all of the DEI units. Also not having to have a seperate alarm unit and having it integrated into the key? Nice
Style trying to figure out what relay I would use- do our parking lights take 30amps?
Old 09-23-10, 10:33 AM
ClearP
ClearP's Avatar
Woo does this replace the aftermarket sound? If it does I want one lol
Old 09-23-10, 10:36 AM
abounly
abounly's Avatar
finally! i was looking for something like this kinda.
i wanted to get the city lights flashed when i lock or unlock the car, sometimes its hard to hear the beep since its not that loud. i believe thats what your going for klaus and the beep.
i never knew the 92-94 didn't beep. i usually just spam the lock button just to be sure
Old 09-23-10, 10:54 AM
Klaus
Klaus's Avatar
So here's the deal with the 92-94 system.
There is just one button for both lock and unlock functions. If they were seperate no big deal. But right now the only way to know the car even recieved the lock/unlock command is to be close enough to hear the locks work. However, you have no clue if you just locked the car or unlocked the car. Annoying. This module will be able to give you both an auditory and visual (if I can find the right relay) cue that it has in fact locked or unlocked as they updated with the 95+ models.
And yes you should be able to use this as a speaker for an aftermarket alarm, I don't see why not!
Does the 97 not flash? I know 95s do
Old 09-23-10, 10:59 AM
abounly
abounly's Avatar
Naw the 97 do not flash, or mine doesn't the 95s flashed? I had a 95 before and i dont remember it flashing.
Old 09-23-10, 11:35 AM
kwg
kwg's Avatar
yeah im a bit paranoid sometimes if i locked my car or not. i always double check and look inside at the locks now or try to open it if its dark
Old 09-23-10, 11:39 AM
ClearP
ClearP's Avatar
Let me know if this replaces aftermarket sound, I hate the ricer sound it gives out!
Old 09-23-10, 11:50 AM
Sup2jzgte
Sup2jzgte's Avatar
Hey Klaus I believe I have the wiring for the SC300...........if you need it.
Not sure if this will help or not
Quick Reply: Finally doing something about the "silent" lock in the 92-94 SC
