SC- 1st Gen (1992-2000)
Fender removal DIY
Old 11-27-10, 02:04 PM
BigManne
BigManne's Avatar
thanks for the DIY.
Old 11-27-10, 03:28 PM
Kyle1JZ
Registered User
Kyle1JZ's Avatar
nice DYI man. Helpful if I ever need to do this =D
Old 11-27-10, 04:50 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Another DIY added to my favorites. Thanks
Old 11-27-10, 06:03 PM
sc3tech
sc3tech's Avatar
thanks. im about to do this myself.
Old 11-30-10, 07:32 AM
soarerdd
soarerdd's Avatar
I knew someone else was going to ask the rotor question. They look nice, but looks like its been dragged on rotors.
My buddy had his 300zx stolen and they took the rims and this exact thing happened to his rotors. All I could think of as a possibility now. lol
Old 11-30-10, 09:27 AM
good2go
good2go's Avatar
I can't imagine how that wouldn't cause a wheel imbalance issue.
Old 02-23-12, 04:41 PM
oneforspaw
oneforspaw's Avatar
thank you sir,
i am replacing both fenders tomorrow with wide body fenders and re-routing my harness on the
drivers side.
Old 02-26-12, 06:58 PM
Reesetrict
Reesetrict's Avatar
HAHAHA My fenders had a ton of dirt and leaves too. My thought... Weight reduction! Excellent DIY, the bolts are a PITA to find.
Old 02-26-12, 07:16 PM
1WILLY1
1WILLY1's Avatar
Originally Posted by TankMR
Why are we taking our fenders off, guys?
well mine is damaged and needs replacement so im glad to get an idea of what its about before I go in blind.
Does a removal fender DIY somehow bother you?
Old 04-16-13, 08:02 PM
313sc3
313sc3's Avatar
If you have a 97+ dont forget to take the front half of the skirt off to access the bolts on the bottom of the fender.
Old 04-17-13, 07:47 AM
Cleanshots
Cleanshots's Avatar
your rotors are on wrong sides.. the slots are pointing the wrong way.. just an fyi..
Old 04-17-13, 08:16 PM
abounly
abounly's Avatar
Hahah, i sold the car almost two years ago. I have my GS now. Don't you check my fb?
Old 07-11-15, 07:19 AM
DrewL
DrewL's Avatar
Still a helpful thread a few years later.
I just removed my fender due to the paint peeling and metal rusting on the top. I removed it with the wheel on since that is what I will need to do in the salvage yard where I am getting a replacement fender. I may need to fend off a few rats in the salvage yard when I'm removing that fender.
Here's a pic of all of the bolts, screws and nuts I had to remove to get the passenger side fender off. It took me about an hour with minor distractions. The wrenches are all 10mm. The screw in the bottom left corner is the only one I had to remove from the fender lip.
spuds (01-12-20)
Old 09-06-16, 01:51 AM
FiSta
FiSta's Avatar
Originally Posted by abounly
bump...how do you exactly remove the front half of the skirt?
there are two yellow tabs; i believe the picture above shows one of them.
Do you just push/pry these tabs thru?
Old 09-07-16, 08:47 PM
sunny416
sunny416's Avatar
Thank you for this. I was looking for one diy a couple of weeks back. Will use this for reference when I have to take mine off.
Quick Reply: Fender removal DIY
