SC- 1st Gen (1992-2000)
$1600 SC400 worth it?
Old 10-04-10, 09:28 PM
  #31
lil23pinoy
lil23pinoy's Avatar
k SO! steering fixed. Replaced the blower motor. Its a tad bit stronger but not much. Filter was cleaned also and still not that much of a diff. Just enough to where u can tell though. NEXT problem. The car didnt start for me the other day. Wont start when its cold out, but it will start no problem in the heat. SO im almost positive its the starter. Bought a starter today for $119. Of course the damn starter is a B!T*H to get too! I made an attempt at it today but stopped cause I was getting PISSED lol if anyone knows where a good DIY is with pics PLEASE let me know!
Old 10-04-10, 09:49 PM
  #32
1uzDreamSC
1uzDreamSC's Avatar
that is a good price for those easy fixes
Old 10-04-10, 09:51 PM
  #33
1uzDreamSC
1uzDreamSC's Avatar
never mind if you have to replace starter then it wasn't worth it lol
Old 10-08-10, 12:38 PM
  #34
TechGreek
TechGreek's Avatar
Is the car trying to spin over in the cold at all? Starter's usually aren't temperamental in different conditions. You can get the old one tested at AutoZone / Advanced Auto
Old 10-08-10, 12:46 PM
  #35
lil23pinoy
lil23pinoy's Avatar
ya it turns just doesnt start. Almost like its getting no fuel. It will ONLY start when its hot out. Cold=no start
Old 10-08-10, 01:41 PM
  #36
Mike552
Mike552's Avatar
fuel filter?
Old 10-08-10, 03:01 PM
  #37
TechGreek
TechGreek's Avatar
Well buddy, the starter is not going to fix that. That will only help in it not turning over fast enough.
To test it, pull your front cover off over the spark plugs. Wait until it's been over night and it's cold. Put your key and turn it over three times. At that point fuel should be in the cylinder and pull the #1 plug (easiest to get to) and see if the plug is wet.
You also need to check to see if you're getting spark, take the boot off plug number one and put the plug in there OUTSIDE of the head (so in other words, take it completley out) and lay it on top of the motor. KEEP YOUR HANDS OFF THE METAL. Have a friend turn it over a few times to see if you see the spark plug arcing.
With it being cold and hot, usually imo, the most common problem is fuel delivery. The O2 Sensors, coolant temp sensor, etc all tell the ECU what to do. If the ECU doesn't think adding more fuel in is worth the time, it won't (i.e. bad sensor somewhere). I know these cars are starting to have issues with the ECU's going out too.
Old 12-20-10, 09:18 PM
  #38
lil23pinoy
lil23pinoy's Avatar
K so replaced the starter and it solved the problem...starts like a champ now. BUT now my MAF sensor went bad. I think this is the 2nd time its gone out cause in the trunk was another bad MAF just chilln there from when I had bought it...BUT HEY GUYS THANKS FOR ALL THE HELP!! appreciate it, seriously
Old 12-21-10, 09:21 AM
  #39
LEX_MAN
LEX_MAN's Avatar
This is just the beginning my friend. Wait until you get to the LCA bushings ,lol
Old 12-21-10, 09:45 AM
  #40
Kira X
美少女戦士セーラームーン
Forum Moderator
Kira X's Avatar
There seems to be a lot of issues with this car. Hopefully everything gets fixed soon and you can get some mods.
Old 12-21-10, 09:59 AM
  #41
lookEVO
lookEVO's Avatar
You still have the sc3? What year?
Old 12-21-10, 04:12 PM
  #42
lil23pinoy
lil23pinoy's Avatar
it was a 94 navy blue sc300. sold it already though.
Old 12-21-10, 04:44 PM
  #43
lookEVO
lookEVO's Avatar
oh ok, cool. I just got a 95 sc300 a couple months ago
Old 12-21-10, 06:49 PM
  #44
313sc3
313sc3's Avatar
Good pickup. I would of told him $1000. Watch out for all the common sc400 problems. Let's see some pics so we could make a better judgement.
Old 12-22-10, 03:06 AM
  #45
lil23pinoy
lil23pinoy's Avatar
K so just need to replace the MAF. than need to figure out how to do a needle rebuild, AND WERE DONE. can start modding. First on the list will prob some coilovers. The struts are out.
Lextreme
Performance & Maintenance
25
08-05-05 08:49 AM
jwar
03-19-03 12:40 AM
jderry
04-30-02 12:19 PM
Quick Reply: $1600 SC400 worth it?
