SC- 1st Gen (1992-2000)
wise lip to fit 97+ bumper?
Old 09-01-10, 09:59 PM
N00bie909
N00bie909's Avatar
Default wise lip to fit 97+ bumper?
has this ever been done before? Im about to start this project real soon anyone have shots of a finished product? I googled and searched but found nothing... thanks cl.
Old 09-01-10, 10:30 PM
chnk
chnk's Avatar
i think it can be done the same way the stock lip is done, i say do it
Old 09-01-10, 11:28 PM
N00bie909
N00bie909's Avatar
Well I'm going to order the lip sometime next week since I'm painting my bumper why not make the paint match perfect right? I was just hoping to see the finished product and how low it sits so I can match up my side skirts.
Old 09-02-10, 09:31 AM
rcsup1
rcsup1's Avatar
Pulled this off a thread a while back. I believe its an authentic 97+ wise lip but I'm not sure.
Old 09-02-10, 12:49 PM
aEO 37
aEO 37's Avatar
I did it but the top of my lip actually sits higher. Its sits right at the bottom of the lower grille.
Been wanting to fix and it and lower it but I have no ideal on how I would go about attaching in the front area.
Ill take pictures of mine later
Old 09-02-10, 01:05 PM
N00bie909
N00bie909's Avatar
i think the blue sc has a vertex lip? and the gold one has a wald lip? but i might be wrong.
yeah please take pictures i might be able to help you im thinking of cutting it in half then fiberglassing the gap then blocking it down so i use the least amount of body filler.
Old 09-02-10, 01:18 PM
aEO 37
aEO 37's Avatar
your are definitely have to cut it in the middle and extending it a couple of inches with fiberglass.. But the shape of the wise lip is pretty much the same as the bumper, it wraps around it pretty good
Old 09-02-10, 01:25 PM
TougeSC3
TougeSC3's Avatar
You are correct Sir. The blue one is rocking a Vertex lip, but it is custom made out of carbon fiber. Gold one is rocking a Wald lip kit.
If you can pull this off it should be interesting. Check your mounting points and you may need to do a bit of fiberglassing on the upper edge of the lip to match the contour of the 97 bumper.
Old 09-02-10, 07:55 PM
aEO 37
aEO 37's Avatar
Ok here are some pictures from my iPhone. This is an fiberglass replica that I got from Raceonusa. Had it cut in the middle and just extended it and screwed it onto the bumper. Cost me probably the same amount as the Big Win lip but I did not have to wait for it.
[IMGhttp://i1007.photobucket.com/albums/af194/aeo37/IMG_0067.jpg[/IMG]
Old 09-02-10, 10:22 PM
Superjatt
Superjatt's Avatar
Just me or the pics not working?
Raceon sells lips?
Yo david why dont you just get the acs bumper and make a lip out of that?
Old 09-02-10, 10:48 PM
N00bie909
N00bie909's Avatar
Raceon sells lips?
Well to cut up the bumper up and fit it on the 97 just sounds like too much work I would have to fiber glass stuff and fill a lot of othere things just isn't worth it. Plus the wise lip is already a lip all I have to do is cut that in half and fill it and also cheaper.
Old 09-02-10, 10:52 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
I thought somebody had already done this before? I'm probably getting all of these different lips mixed up though.
Old 09-02-10, 11:56 PM
Superjatt
Superjatt's Avatar
i actualy found some random *** lip that was just in the streeet after a hit and run. =]
Old 09-03-10, 03:52 AM
aEO 37
aEO 37's Avatar
Raceon sells lips?
Lol, Guess the OP has the same name as I do.
Raceon did sell the lip, but it was for a 92-96 front end and I had this cut and extended for the 97+ front
Old 09-03-10, 08:33 AM
N00bie909
N00bie909's Avatar
Nice job there are some little imperfections I'm sure you can fix what part of cali are you located? I had no idea that the lip went inside the bumper by the grill area.
Quick Reply: wise lip to fit 97+ bumper?
