SC- 1st Gen (1992-2000)
shaving fenders?
Old 08-28-10, 10:29 PM
chnk
chnk's Avatar
Default shaving fenders?
alright, i've been needing to roll my fenders and the purpose of rolling fenders is to bend that lip inside the fender. Well I have a dremel with a cutting disc and lots of time tomorrow. Why not just cut the that lip off?
I don't hear too much about shaving fenders around these forums is there a reason why?
Old 08-28-10, 10:42 PM
FireCode
FireCode's Avatar
Structural integrity maybe? Just a thought that comes to me.
Old 08-29-10, 01:14 AM
818sc400
818sc400's Avatar
jus use a heat gun and a baseball bat. heat up the fender so it dont crack then stick a baseball bat there. look up youtube. if your gonna take it in to someone its gonna be $40 per corner. i never heard of anyone using a dremel. gl
Old 08-29-10, 02:19 AM
Black_SC
Black_SC's Avatar
it weakens the quarter panels...
Old 08-29-10, 06:06 AM
ScottURnot
Super Moderator
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Lots of guys actually cut the lip. The rears have a lot of support so its not a big deal on them, the fronts however are different. My main reason to roll verses cut is to avoid a sharp edge in the event to tires do rub. Rolling the SC fenders is tricky, the moulding holes are known to cause ripples on the fender.
There are lots of threads on rolling and cutting fenders with pros and cons on both, use the search and you should find them.
Old 08-29-10, 10:11 AM
chnk
chnk's Avatar
I've search the forums on rolling the fenders with a baseball bat and for the front I heard it wasnt a good idea
i've search and didnt see much but then agian i didnt try cutting fenders
I really just need to cut the rears so that sounds but sharp edges dont sound good at all,
time to buy a basball bat
Old 08-29-10, 10:24 AM
ronricorum
ronricorum's Avatar
just get a good shop to roll it for you. better to pay the 40-50 per fender than if you mess up and have to go thru that process
Old 08-29-10, 11:07 AM
chnk
chnk's Avatar
Alright ive done a lil more reading and deciding on cutting the rears and then rolling it when i can get my hands on a fender roller to do a slight pull/flare then priming the parts I cut to avoid rust
concerns i have read about though, now when ppl cut the fenders they say dont cut too far, im assumming cutting the lip off to the edge of the fender
Old 08-29-10, 11:21 AM
BartleDoo
BartleDoo's Avatar
I cut my fenders because I didn't want to end up with wavy fenders and cracked paint, and because it was easier. I used an angle grinder and the trick I was told is to put masking tape over the cut line to keep the paint from peeling. It worked well. Just make sure you angle the cutting side of the cut-off wheel into the car so you don't risk skipping off the lip and onto the fender.
Old 08-29-10, 03:23 PM
MIKU*SC3
MIKU*SC3's Avatar
If your rubbing only a little bit then just use a rubber mallet and a vice grip. Although it sounds stupid it wors.
Thats what i used on my rear fenders so ya. hahaha
Or you can do what this guy does. http://www.youtube.com/watch?v=DDTK9IjKIYU
Old 08-29-10, 03:52 PM
Black_SC
Black_SC's Avatar
that guy is crazy haha
Old 08-29-10, 04:04 PM
SChema
SChema's Avatar
My rears are cut as well, I have not seen any problems since.
Old 08-29-10, 04:51 PM
96SC4
96SC4's Avatar
+1.............
Old 08-29-10, 04:55 PM
ashtray
ashtray's Avatar
im with this
Old 08-29-10, 04:58 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Talking
I remember seeing that video before I bought my SC. I want to buy a mallet!
Have you had any rubbing issues on your XXR's or the SSR's? Also, how wide are your new wheels?
Quick Reply: shaving fenders?
