SC- 1st Gen (1992-2000)
1JZ swap questions...
Old 08-09-10, 10:40 PM
Munki
Munki's Avatar
Default 1JZ swap questions...
I just bought a 1jz swap with 5-speed from a chaser or soarer(forgot what car it was from...) with rear sump, and now I got a few questions about the swap...
What driveshaft will I have to use? Will the auto driveshaft from a 92' auto work?
Would the w58 tranny mount work?? And what clutch pedel set-up do you guys usually use for the 5-speed swap??
Old 08-09-10, 10:57 PM
wagomaniac
wagomaniac's Avatar
You need to search. Im sure you will find everything with searching. Good luck
Old 08-10-10, 07:28 AM
OneJay
OneJay's Avatar
Well if it's rear sump it's either from a Soarer or Supra. And no the auto driveshaft will not work.
Old 08-10-10, 07:49 AM
Munki
Munki's Avatar
So i've been reading that you need a mkIII front half of the driveshaft? The rear half works im guessing. The only problem with that is a mkIII driveshaft is almost impossible to find in my area..... The only driveshafts I can find are from a non-turbo or auto turbo mkIII.
Old 08-10-10, 03:27 PM
pmpdaddyt
pmpdaddyt's Avatar
or u can get the Driftmotion.com drivestaft for a couple hundred bucks
Old 08-10-10, 04:47 PM
Munki
Munki's Avatar
I looked into that. the cost is over 200 bucks though... lol
400 for the driveshaft and 160 for the adapter. would i be able to use the front driveshaft from a non-turbo 5 speed mk3???
ReganSC300
02-26-11 02:48 PM
nyjdmevo
Performance & Maintenance
05-17-09 12:30 PM
SCjzz
08-21-08 03:19 PM
tranjq
CL of Southern California
10-24-07 02:33 PM
bigdaddyrobb
04-08-06 08:24 AM
Quick Reply: 1JZ swap questions...
