SC- 1st Gen (1992-2000)
SC300 smog results-pre and post O2 sensor+ 11K miles w/picture
Old 07-28-10, 06:26 PM
ISFFUN
ISFFUN's Avatar
Default SC300 smog results-pre and post O2 sensor+ 11K miles w/picture
Here are my smog results from 2008 and 2010. AFAIK the car has the original plugs and wires, O2 sensors etc. The car is not from CA but now lives here. I've typed the actual values (15mph only) in case the image is taken off the host.
The significance of this is that in 2008 my HC PPM was at the threshold for passing. In 2010 and 11,000 miles later, I changed the #2 oxygen sensor and my HC PPM changed drastically, but time hasn't fared well to the NO PPM numbers. I still haven't changed the plugs and wires. The PCV valve was changed about 1,000 miles ago. Does anyone know what the NO PPM numbers are linke to? Bad spark plugs? Cat?
The underlined values are lower and the bold values are higher.
2008 - @ 112,150 miles
RPM - 1659
%CO2 - 14.6
%O2 - 0.2
HC PPM (Max-49) Meas = 49
CO% (Max-0.47) Meas = 0.22
NO PPM (Max-409) Meas = 6
2010 @ 123,435 miles
RPM 1696
%CO2 - 14.6
%O2 - 0.2
HC PPM (Max-49) Meas=27
CO% (Max 0.47) Meas=0.03
NO PPM (Max 409) Meas = 107
LexBrett
09-26-14 12:52 PM
ptplujo
Performance & Maintenance
04-20-13 10:08 PM
ISFFUN
10-23-11 10:46 AM
StanVanDam
06-01-10 02:13 PM
Quick Reply: SC300 smog results-pre and post O2 sensor+ 11K miles w/picture
