SC- 1st Gen (1992-2000)
where is the fuel pump on a sc400?
Old 07-21-10, 05:14 PM
iridebmx
iridebmx's Avatar
Default where is the fuel pump on a sc400?
where is he fuel pump on this car? 1994 sc400? and what ALL DO I NEED TO DO TO GET TO IT!
i just reset my ecu and all my problems are infact a bad fuel pump Code 78.
also would it be ok if i just got a walbro 255 because i cannot afford a OEM fuel pump for $500...
thanks and please answer ASAP!! i need to get to school reliably after i order a new fuel pump
Old 07-21-10, 05:36 PM
turbodremz
turbodremz's Avatar
Its behind the rear seat. You must remove both the lower seat section and back section. You will see an 8'' cutout with (IIRC) 8-10mm bolts. simply remove those, and you will see the access panel to the tank...BUT, before you do that, use the forums search function for "12v fuel mod", and you may beable to fix the problem for free by simply doing the 12v bypass mod.
Old 07-21-10, 05:48 PM
Alex L.
Alex L.'s Avatar
The 255 will be fine.
Old 07-21-10, 06:42 PM
iridebmx
iridebmx's Avatar
i have done the bypass and ok sweet deals on the 255!!
also i just looked and looks like the fuel pump is in the trunk behind all the covering on the tank... am i wrong? i disconnected the plug and the fuel pump turned off so i am assuming thats the fuel pump just like a 240 or something...
Old 07-21-10, 07:30 PM
iridebmx
iridebmx's Avatar
another 2 question how do i add more voltage to the fuel pump? and what walbros fit my car??? do the 1990 to 2000 fit the 1994 model? i cant find it anywhere
say i buy the 255 and want to add the extra 1.5v for the max of 13.5 for max pumping what do i do??
Old 07-21-10, 09:03 PM
SC400TT
SC400TT's Avatar
Just as Turbodremz stated, the fuel pump is "Absolutely, 100% located in the tank, behind the rear seat. If you wish to remove the pump, you must remove the complete back seat (upper and lower), and access the circular panel to get to it. The stock pump is attached to the stock hanger, and resides within the slosh tank inside of the fuel tank. You can strap a Walbro 255 onto the hanger. Be sure to disconnect power before attempting this.
Ryan
Old 07-21-10, 09:15 PM
spdrcr771
spdrcr771's Avatar
That would be the fuel level gauge under that cover. And the one on top is the vent line. Yes one of the plugs does control weather the pump comes on or not. I dont know if that is the main power for the pump or not but do know the pump doesnt work if its not plugged in.That is the one thing Ive never replaced on any of my SC's "fuel pump". Probably just called the "witch doctor" a mother******.
Old 07-21-10, 09:22 PM
ZPEED
ZPEED's Avatar
that bypass ECU might cause of fuel pump failure. it keep running the fuel pump even if the engine is off..
Old 07-21-10, 09:25 PM
Alex L.
Alex L.'s Avatar
Take your rear seat out, replace the pump. Seriously, it's that easy.
Old 07-21-10, 09:33 PM
turbodremz
turbodremz's Avatar
no sir you are wrong..search before you post incorrect info please
Old 07-21-10, 09:48 PM
ZPEED
ZPEED's Avatar
ask SC250tt , he will tell u the side effect in this mod. )
Old 07-21-10, 09:50 PM
turbodremz
turbodremz's Avatar
Im telling you from over 2yrs of having this mod with a Walbro 255, not one problem..not to mention all the other members with the 12v mod that will also tell you otherwise...just cause one person had a problem, dosent mean jack except something went wrong with his car.
Old 07-22-10, 10:16 AM
FutureSC
FutureSC's Avatar
Pictures always make the world a better place! :P
Old 07-22-10, 10:25 AM
turbodremz
turbodremz's Avatar
I was looking for that diagram but couldnt remember where I have it saved. Thanks for putting that up for everyone
Old 07-22-10, 10:27 AM
FutureSC
FutureSC's Avatar
Yeah yeah no prob I know I've posted it a couple other times too. Maybe I should actually make a decent looking one some day that's actually cropped correctly haha
Quick Reply: where is the fuel pump on a sc400?
