SC- 1st Gen (1992-2000)
Stock 2jzgte and a tune
Old 06-18-10, 07:06 AM
venom350gt
venom350gt's Avatar
Default Stock 2jzgte and a tune
What kind of hp and whp numbers should i expect after i finish the swap. 92 sc300 swapin the aristo gte motor with usdm turbos and fmic and an SAFCII. the harness is just getting finished up and i should have it back tues or wednesday? former G35 owner so not sure what to expect with the toyota. eventually soon i will do bigger injectors, cams, and fuel pump. my goal is 450-500whp. trying to setup for drift.
Old 06-18-10, 10:20 AM
Li Ls4
Li Ls4's Avatar
At 18 lbs my cousin was making just over 400hp in his MK4 supra. So I would think u should b able 2 break 400hp depending on how agressive your tune is.
Old 06-18-10, 10:52 AM
S142jz
S142jz's Avatar
about 420.
Old 06-19-10, 01:11 AM
venom350gt
venom350gt's Avatar
thats great to hear been a little nervous about this build
Old 06-20-10, 02:03 PM
venom350gt
venom350gt's Avatar
anyone got any tips on changing the motor from a front sump to rear sump?
Old 06-20-10, 02:25 PM
eliteskill
eliteskill's Avatar
It depends on the OCT of gas you are running.
93 OCT @ 18psi expect = 350-380 rwhp.
440CC JDM injectors are going limit you. JDM Cams are going limit you.
Even after fuel upgrades and cam upgrade if you want 450-500rwhp. Dont expect that out of USDM stock turbos even with Race Gas @ 21psi. You are going hurt your turbos bad. You need to go single or upgrade the turbos by then.
I have USDM turbos/cams/550cc injectors/2jzgte fuel pump (good for 550hp). I dyno'd at 350rwhp~ @ 15psi on 91 oct.
Old 06-20-10, 02:39 PM
frankdms
frankdms's Avatar
Do it right. J/k man, it is easy. Find a sc300 motor (2jzge) off car-part.com look for core motors listed and be sure to get all the bolts as well as a NEW puckup tube +gasket sealer and pickup tube seal from toyota/lexus (see vendor section). GL man should be a fun car!
edit: was your car a sc3 or 4? If it was a sc3 you have all the old parts on your old motor for the rear sump swap.
Old 06-20-10, 02:44 PM
frankdms
frankdms's Avatar
Do it right. J/k man, it is easy. You do know that 2jzge/gte as well as 1jz parts all swap back and fourth right? Use your old rear sump setup. Was your old oil pan damaged? If so find a sc300 motor (2jzge) off car-part.com look for core motors listed and be sure to get all the bolts as well as a NEW puckup tube +gasket sealer and pickup tube seal from toyota/lexus (see vendor section). GL man should be a fun car!
Old 06-26-10, 05:53 PM
venom350gt
venom350gt's Avatar
yea i have the stock motor from the sc3. i plan to to cams, injectors, walbro, and cam gears but funds are running low so just trying to get an idea of where i would be with what i got right now. trying to do side jobs to make extra and sell all my stuff i dont use anymore
Old 12-17-11, 05:20 AM
AZBMW
AZBMW's Avatar
Hows this coming along?
Old 10-30-13, 02:02 PM
solowlex
solowlex's Avatar
Any updates?
Old 10-30-13, 07:14 PM
soarer13oy
soarer13oy's Avatar
This plus you will need a down pipe 3" exhaust.
2jdeemo
Performance & Maintenance
07-03-14 01:39 PM
Medic91x
05-31-13 12:08 AM
Cleanshots
07-05-08 06:33 PM
slappy96
04-02-08 03:52 PM
DSMpower
11-10-07 12:27 AM
Quick Reply: Stock 2jzgte and a tune
