Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300
Sign in using an external account
Register Forgot Password?
Tilt steering repair
Thread Tools Search this Thread Display Modes
Old 06-20-03, 09:26 AM   #16
LexusBiz
Trader Score: (0)
This is what makes the CL such a great forum!!! Useful info, helpful hints.
Question, what kind of lubricant should I use on the gears.
Keep the great info rolling.
Thanks
LexusBiz
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
LexusBiz is offline   Reply With Quote
Old 06-20-03, 10:27 AM   #17
duclex
Trader Score: (0)
LexusBiz,
VVTi posted a while ago in another thread
"Then you will see the motor(round in shape) and some kind of worm gear, may be the gear need to be lubricated. The part# for Lexus is 08887-02007( Body Grease W). DO NOT USE ANYTHING ELSE. This is the special grease for all of the steering column and if you use 4WD or wheel bearing grease it will make it worse.
The best way is go to Lexus dealer and ask one of the tech. to spare one of the steering column grease. Tell them the yellow grease they used when they rebuild the steering column on the LS and LX. They probably have about 100 of them around the shop. Try this first before buy the motor."
This job only took me the afternoon, much time was just looking for tools and parts. 10mm, 12mm, phillips screw driver, understanding which parts to take out...etc.
Duc
duclex is offline   Reply With Quote
Old 08-19-04, 12:28 AM   #18
agapepaga
Trader Score: (0)
agapepaga's Avatar
Send a message via AIM to agapepaga
I bought my SC with this problem and had resigned to the fact that I'd have to drive with the wheel in the "up" position forever or until I could afford to drop $600 on the motor. Thank you so much for this guide!! I'm in love all over again!
agapepaga is offline   Reply With Quote
Old 08-19-04, 06:23 AM   #19
dlomshek
Trader Score: (0)
Thumbs up
Thanks c_irie, super informative post. These type of posts make CL such a great forum.
dlomshek is offline   Reply With Quote
Old 08-19-04, 07:07 AM   #20
SolShinobi
Trader Score: (0)
SolShinobi's Avatar
Thumbs up thanks c_irie and duclex
That's very good info.
I just got my 98 SC3 so i'll definitely remember this topic name for a key search.
SolShinobi is offline   Reply With Quote
Old 08-19-04, 11:03 PM   #21
96sc3
Trader Score: (1)
Send a message via AIM to 96sc3
very nice work
__________________
turbo
96sc3 is offline   Reply With Quote
Old 11-09-04, 11:04 PM   #22
lexus hawaii
Trader Score: (0)
Thumbs up tilt steering repair
c_irie, Thank You Very Much! Just got my 94 SC 400 3 weeks ago. With only 18,000 miles, who would've thought anything would go wrong. Followed your insturctions and voila it works great. Aloha, Lexus Hawaii
lexus hawaii is offline   Reply With Quote
Old 11-10-04, 12:31 AM   #23
DM-S4
Trader Score: (0)
Yup, I did it as well. Although I could not find the right washer, just by cleaning and regreasing with that yellow stuff, it works great. I took off the auto tilt so it will be used alot less.
__________________
'01 Audi S4
'95 SC 400
DM-S4 is offline   Reply With Quote
Old 11-10-04, 02:24 AM   #24
joshthorsc
Trader Score: (0)
joshthorsc's Avatar
Nice, nice!! If my tilt wheel ever goes out, I'll definetely follow your example!!
joshthorsc is offline   Reply With Quote
Old 03-05-05, 02:24 AM   #25
TWISTED II
Trader Score: (0)
i'm becoming the master of reviving old posts. but i come from a land of being on top in the forum, and telling the noobs to search, so, i take my own advice when i'm the noob, lol.
just saying thanx for the good info. along with all the other surprises i've found with this car a week ago when i bought it, this was another one. and another problem helped with to a fix from CL.
TWISTED II is offline   Reply With Quote
Old 03-05-05, 02:30 PM   #26
Goldark
Trader Score: (0)
Send a message via AIM to Goldark
nice
I'm sure a lot of us will find this helpful
__________________
I ride a goat.
Goldark is offline   Reply With Quote
Old 03-10-05, 09:31 AM   #27
UltraLexx
Trader Score: (0)
Default nut still spins
I have the same prob. on my LS. I took eveything apart as per dir. I tried to loosen the nut that holds the gear in place and the whole shaft spun including the gear (which didn't help the revive the stripping) How did you hold the gear in place and remove the nut?
UltraLexx is offline   Reply With Quote
Old 03-10-05, 12:51 PM   #28
TWISTED II
Trader Score: (0)
mine just came lose after a while of trying to get it off. i was about to go to a friends shop to use an impact on it, just to kick it lose, but i kept messing with it, and it eventually losened up. but i thought i was going to have this same problem for a while. the next problem was removing the blue gear, lol. what a pain, but, mini allen keys being held by pliers worked well, lol.
Old 03-11-05, 12:46 PM   #29
JspecSC3
Trader Score: (4)
JspecSC3's Avatar
Quote:
Originally Posted by c_irie
anyway I looked on the forum since I remembered seeing a post on the subject before
I believe that was me. But yeah, very nice job with the step by step explanations and detailed pictures. It will help me out a whole lot. Thanks!
JspecSC3 is offline   Reply With Quote
Old 03-11-05, 01:32 PM   #30
newyorksc
Trader Score: (0)
c_irie posted on this original thread that was started three years ago
JspecSC3.. you just registed Jan 2005
unless you have a different name three years ago im unaware of
newyorksc is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power tilt-away repair.. "How to" tutorial Stereorob LS400 21 02-13-14 01:27 PM
Steering Wheel Tilt Motor Inoperative willcrets LS400 7 04-11-13 05:57 PM
Inoperable tilt wheel mechanism repair oldyngoody LS400 2 09-18-12 12:39 PM
Tilt steering inoperable on 1998 LS400 Wallace LS400 2 09-07-12 03:52 PM
No more tilt mike2002 LS430 1 08-03-12 09:46 AM
Tags
broken, column, fuse, infinity, lexus, location, ls400, lx470, motor, q45, repair, sc400, steering, telescoping, tilt, wheel, work
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
