Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300
Sign in using an external account
Register Forgot Password?
Tilt steering repair
Thread Tools Search this Thread Display Modes
Old 10-21-08, 03:29 PM   #151
Cleanshots
Trader Score: (2)
Cleanshots's Avatar
Send a message via AIM to Cleanshots
Quote:
Originally Posted by acenase View Post
What size wrench do I need to unscrew it? I tried everything but couldn't get it to fit. The wheel is very loose, I can push it back and forth.................
dude, have you looked what that metal thing is and if you can take it off? and also try different sizes its one of those sizes.. COMMON.....
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
94 Sc300 Blk on USB 5spd 1 of 227 #076
2Jz-gte, Turbonetics T72-70, aeromotive, R154, BC racing, koyo, Act, HKS Hi Power, zirgo, TRS, Momo, Tial, BrianCrower, Fluidamper
Check out my threads and leave some love.
Stage1: Build and GTE Swap.
Stage2: Paint!
Ongoing Photoshoot Thread.
Cleanshots is offline   Reply With Quote
Old 10-21-08, 07:20 PM   #152
KrazeMatik
Trader Score: (11)
too lazy to read 11 pages..... was tilting it back and foward not working or up and down?
KrazeMatik is offline   Reply With Quote
Old 10-22-08, 05:27 AM   #153
setwire
Trader Score: (0)
Quote:
If you can't read 1 page of directions then you must also be too lazy to fix it as well.
Take it to the dealer and spend the $900. to have them repair it for you.
setwire is offline   Reply With Quote
Old 10-23-08, 04:11 PM   #154
acenase
Trader Score: (0)
The Metal thing can't come off. I think I need an adjustable wrench. because I've tried 3/8, 7/16 and it's either too big or too small.
My tilt doesn't go up or down because the wheel is unaligned with the screw above it.
acenase is offline   Reply With Quote
Old 10-28-08, 04:45 PM   #155
shinesc
Trader Score: (0)
I just save $900....mad prob!!....thanks so much dude.
shinesc is offline   Reply With Quote
Old 11-04-08, 07:51 AM   #156
fcaines
Trader Score: (0)
Default Power steering
I just took a chance on buying a 95sc 400 with 175K on it. I knew it needed work. With the help of this forum I was able fix my tilt steering. Thanks so much for the information!
Frank
fcaines is offline   Reply With Quote
Old 12-05-08, 01:21 PM   #157
shajbot
Trader Score: (2)
shajbot's Avatar
My Tilt til up but not down. What do I do? I have the blue ring removed now and No auto tilt. The screw spins up but not down, that's why Im sure it's not becase the blue ring is in the center or not.
shajbot is offline   Reply With Quote
Old 12-05-08, 01:47 PM   #158
Ali SC3
Na-T Guru
Trader Score: (10)
Ali SC3's Avatar
sounds like your connection to the switch is bad or the motor is not going into reverse.
when you press it to go down, do you hear anything happening?
if the screw does not move at all, ur right, that would not be a centering issue.
generally if an electric motor spins one way, it should be just fine spinning the other direction when the polarity is reversed. So then i would check the connectors.
If for some reason two seperate motors are used for up and down which seems rather silly to me, it could be either the motor or connection or both.
__________________
1995 Lexus SC300 5spd Na-T ( TT Ecu Mod + a few others)
Ali SC3 is offline   Reply With Quote
Old 12-05-08, 02:51 PM   #159
shajbot
Trader Score: (2)
shajbot's Avatar
Yeah motor spins one way (up) and when it doesn't spin down, it doesn't make any noise or anything at all.
I don't know if I want to open up the **** again, what a hella grease mess...
Old 01-02-09, 10:20 PM   #160
lilSCsteve
Trader Score: (58)
lilSCsteve's Avatar
Gotta love this forumn, I've been slowing restoring my SC to new with you guys help...save me a lot of cash. Thanks guys!
lilSCsteve is offline   Reply With Quote
Old 01-29-09, 01:15 PM   #161
GED2Phd
Trader Score: (0)
Wow, I feel ripped off. I read several posts that claim they spent anywhere from .27 cents to .99 cents on garden hose washers. I just spent a whopping 1.99 plus CA. sales tax for a grand total of $2.15. Although there were 10 garden hose washers in the package, I'm still slightly green with envy.
By the way, the fix worked perfectly well. I had a grinding noise when ever I tried to lower my wheel. It eventually got to the point where it would telescope both directions, go up, left and right--and would grind profusely when trying to tilt down.
Carefully pulled everything off and I only needed two washers behind the blue gear. Works well...Thanks c_irie and the rest of CL!!!
GED2Phd is offline   Reply With Quote
Old 02-04-09, 01:17 PM   #162
2fastek
Trader Score: (0)
my wheel go up and down but not in and out, is that the motor?
2fastek is offline   Reply With Quote
Old 02-06-09, 07:58 PM   #163
naslex1995
Trader Score: (0)
Default thank u
thanks man it does work
naslex1995 is offline   Reply With Quote
Old 02-17-09, 03:30 PM   #164
Lexusdad
Trader Score: (1)
DDDDDuuuuddeeeee........thank you so much for this write up. Before I bought my daughters sc300, I knew that the tilt did not work. Bought it, found this site, and baddda bboommm tilt and telescopic working flawlessly. Hardest part was splitting the plastic clam shell.
Jim
Lexusdad is offline   Reply With Quote
Old 02-22-09, 04:34 PM   #165
ninjarico
Trader Score: (0)
worked like a charm, I used 2 O rings so I didn't even have to pull off the blue gear.
ninjarico is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power tilt-away repair.. "How to" tutorial Stereorob LS400 21 02-13-14 01:27 PM
Steering Wheel Tilt Motor Inoperative willcrets LS400 7 04-11-13 05:57 PM
Inoperable tilt wheel mechanism repair oldyngoody LS400 2 09-18-12 12:39 PM
Tilt steering inoperable on 1998 LS400 Wallace LS400 2 09-07-12 03:52 PM
No more tilt mike2002 LS430 1 08-03-12 09:46 AM
Tags
broken, column, fuse, infinity, lexus, location, ls400, lx470, motor, q45, repair, sc400, steering, telescoping, tilt, wheel, work
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
