SC- 1st Gen (1992-2000)
O2 Sensor Questions
Old 04-27-10, 09:10 AM
TRM09
TRM09's Avatar
Default O2 Sensor Questions
Hi Guys,
Need help on an O2 sensor problem. I've done some searching and haven't been able to find the answer.
I have a 1996 SC 300 manual w/o traction control. My check engine light came on and it suggested that it was the O2 sensor pre cat. I had them replaced. Now the light is back suggesting that its the post cat sensor. I think I have 2 post cat O2 sensors. When I looked for the part at rockauto and oxygensors.com it is telling me that I only have one post cat sensor? I'm confused because I thought I had 4 in total (2 pre and 2 post cat). Also, the one post cat appears to have a plate with 2 holes on it. I can't find this part. What am I missing here??
Old 04-27-10, 09:23 AM
Dx3
Dx3's Avatar
You should have 2 in the front (#10,#11) and 2 in the back (#12, #13). I have no idea what this plate is? Is it a block off plate or something?
Jonny
Old 04-27-10, 09:28 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I'm confused also. U should have only 4 total? Call the local Lexus dealership or Carson Toyota.
Old 04-27-10, 09:31 AM
djrazr
djrazr's Avatar
i thought it was only 3?
Old 04-27-10, 09:57 AM
TRM09
TRM09's Avatar
Thanks guys. I called the local Lexus dealership and they are saying I have 3 O2 sensors. The parts guy at Lexus said that the plate I was referring to is basically a gasket cover, which I would have to take off to access the sensor.
Jonny - you're drawing clearly shows 4 sensors. Do you know if #12 & #13 are the same part like #10 & #11?
I called my mechanic and he swears there are 4-O2 sensors. However, anyone that looks at a manual tells me there are 3. I didn't think this would be so hard. I just need to get under the car and figure it out and then figure out what if the post cat O2 sensors are the same...
Anyone have a drawing/picture of the under carriage?
Old 04-27-10, 10:46 AM
6SOARER
6SOARER's Avatar
My Alldata shows that there is 4 sensors, they are also refered to as A/F sensors-air fuel sensor.
You have bank 1 sensor 1, bank 1 snesor 2, bank 2 sensor 1 and bank 2 sensor 2
Sensors 1 are Pre Cat and sensor 2 are posts cats.
Old 04-27-10, 11:03 AM
6SOARER
6SOARER's Avatar
[QUOTE=TRM09;5439038]Thanks guys. I called the local Lexus dealership and they are saying I have 3 O2 sensors. The parts guy at Lexus said that the plate I was referring to is basically a gasket cover, which I would have to take off to access the sensor.
Front Sensor is identified as part# 8946514120 and the rear sensor is part# 8946529895
Bottom illustration shows you which bank is which:
Old 04-27-10, 11:56 AM
TRM09
TRM09's Avatar
EyeSoarer6, that was very helpful. So since I'm looking to get the post cat sensors then I'm looking for Bank 1-Sensor 2 and Bank 2-Sensor 2. Judging by the part #, both sensors are the same. www.oxygensensors.com has the Denso 234-4214 which I think works. I hope this gets rid of my check engine light and can pass emissions and get a new license plate sticker!!!! Wish me luck!
One last question, your figure 5 states V6 FWD. As you know, the SC300 is an I-6 RWD. Is this still correct?
Old 04-27-10, 12:02 PM
6SOARER
6SOARER's Avatar
Yes, that is correct. its a RWD and I dont really know why they have that diagram listed as a FWD. I entered 96 SC300 and thats what it shows..
Old 04-27-10, 12:12 PM
TRM09
TRM09's Avatar
Thank you! Hope this works!
Old 07-07-10, 10:17 AM
Codfish
Codfish's Avatar
Now I'm confused... The part # I have is 89665-24070.The Lexus dealer said that the O2 sensors (there are only 2 on my car according to them) are the same part...
I called many auto stores around town and most of them say there are 3... I cannot find the other one ???
pieisgude
Performance & Maintenance
05-10-12 08:38 PM
lexusbooty
IS - 1st Gen (2001-2005)
10-13-08 10:13 AM
swifty562
12-07-07 11:41 AM
nicola
08-25-05 08:30 AM
Quick Reply: O2 Sensor Questions
