SC- 1st Gen (1992-2000)
soft brakes on '92 sc300
Old 04-13-10, 07:19 AM
Avarec
Avarec's Avatar
Exclamation soft brakes on '92 sc300
when i press my brakes, car barely stops, brake pedal must be floored real hard
what are things i can check out to solve the issue
Old 04-13-10, 08:04 AM
good2go
good2go's Avatar
Air in the brake lines
Boiled brake fluid
Bad brake line
Bad master cylinder
Brake fluid on pads
Old 04-13-10, 10:18 AM
aka paco
aka paco's Avatar
basically what good2go covered..
does your brake pedal slowly start to sink to the floor if your holding on the brakes? like sitting at a stoplight or something..
i'd definetly start by looking at your brake master cylinder, check the level and condition of your brake fluid..
Old 04-13-10, 07:13 PM
Avarec
Avarec's Avatar
brake fluid seems to be fillled up and is full,
Old 04-13-10, 09:40 PM
t70 supra
t70 supra's Avatar
you could have a bad brake master cylender but if u need sc brakes hit me up i have a complete front set sitting in my garage
Old 04-13-10, 09:45 PM
HellFish
HellFish's Avatar
is your pedal going to the floor or is it still up and hard to press down?
-if its dumping to the floor then id see a problem with the master cylinder.
-if its a tough pedal, like youre on the leg press tryin to push it down, then its most likely the brake booster, or the vacuum line to the booster.
Old 04-13-10, 10:46 PM
Luxor
Luxor's Avatar
Bleed your brakes before you replace anything, it could something as simple as bad brake fluid and/or an air bubble in the system.
Old 04-14-10, 02:27 AM
snowfox444
snowfox444's Avatar
how much do u want for them? i need brakes bad
TolasLV
10-30-17 09:20 PM
NYG
Suspension and Brakes
04-24-13 05:00 AM
Lexus082
10-13-12 05:40 PM
Lexus082
06-21-11 05:39 PM
jimbo22s
07-26-04 07:04 PM
Quick Reply: soft brakes on '92 sc300
