SC- 1st Gen (1992-2000)
Check out my old steering rack bushing.
Old 04-09-10, 08:03 AM
1SICSC4
1SICSC4's Avatar
Originally Posted by cavette
Does the car ride harshly with the Prothane control arm bushings? I heard that polyurethane will squeek and provide a harsh ride compared with rubber. Your thoughts would be appreciated.
You do feel the road a lot more. For better and for worse. It provides my with what I want and thats a sportier feel in the car. No extra noise. I think its worth doing. Under $200 for front and rear control arm bushing and daizen steering rack busings. Best money spent to improve handling.
Old 04-09-10, 08:11 AM
RedPhoenix
RedPhoenix's Avatar
Also in addition... Polyurethane only squeaks when they are not properly lubed. The lubricant does not (or at least I feel this way) disapear significantly over time. Yes it will slowly go away, but the stuff that is provided is almost like glue. It is the most sticky crap ever, but it properly lubes the bushings and will stay there for an extended amount of time. Some people install Zerk fittings to grease the bushings yearly or whatever. Prothane bushings have slits cut into them, so grease fittings would work very well on any of the 2 piece bushings (grease slides through the 2 sections into the slits). This idea will not work on the front lower arms (of all things for this idea NOT to work on...) since it is just a 1 piece bushing.
The steering rack bushings dont need to be greased (even daizen says so) since they are not supposed to move, but safer than sorry.
Old 04-09-10, 09:52 AM
cavette
cavette's Avatar
Does Prothane or Daizen provide the lubricant or do you get it from somewhere else? If not provided, where can we get it?
Old 04-09-10, 10:04 AM
good2go
good2go's Avatar
Every Prothane or Diazen kit I've seen had tons on those lube tubes included
Old 04-09-10, 10:05 AM
1SICSC4
1SICSC4's Avatar
the prothane comes with lube.
Old 04-09-10, 10:20 AM
RedPhoenix
RedPhoenix's Avatar
Prothane comes with 5? small tubes lube, but I also used an additional tube I had laying around. More is better... just make more of a mess haha
Old 04-09-10, 01:25 PM
High PSI
High PSI's Avatar
Originally Posted by 1SICSC4
Check it out. Mint condition. LOL.
That's what mine looked like. Installed the Dazien kit and now it's WAY better. Dazien kit + Supra LCA's + supra sways w/ new bushings and it feels like a new car...
nicks88
11-27-12 09:29 AM
Tommy2JZ
14
05-11-12 10:14 PM
Dslexic
Suspension and Brakes
02-20-09 03:03 PM
manalive20
04-10-07 10:09 AM
neurocity
11-18-06 10:28 PM
Quick Reply: Check out my old steering rack bushing.
