Need some advise for 1uz 5 speed swap what can and cant be used?
Ok i got a OBD1 SC400 that i want to do a 5-speed w58 swap. I just got a donor wrecked 1993 obd1 sc300. So far here are the parts im going to swap over to the sc400.
w58 tranmission
driveshaft
clutch petal
master cylinder
slave cylinder
Automatic sc400 bellhousing
1uz to w58 adapter plate
stock sc300 clutch?
So which flywheel can i use on this? sc300 or sc400? I would still need the howe bearing? whatelse am i missing?
w58 tranmission
driveshaft
clutch petal
master cylinder
slave cylinder
stock sc300 clutch?
i did check it out but im having trouble figuring out about the spacer. In one picture he has a solid spacer that sits behind the howe unit and in another picture on here they are using the spacer from howe which is alot of them stack from behind. does it matter which one you use?
