Transmission Cross member and mount for 1jzgte sc400 with R154 transmission Swap
Hi there Guys,
Can I use my Factory SC400 cross member to install a R154 Transmission? I check it and it won’t fit. Witch transmission mount I have to use with my Factory cross member and the R154 Transmission?
Do i have to make a custom transmission mount to make it fit?
I will appreciate you help.
dude - Search.Everything you need is SC300.SC300 5 speed (or R154 that came on mine) Cross member Will work but Trans mount I;m sure the SC300 Works as well.
I'm Same boat But Theres Threads all over to tell you EVERYTHING you Need.
Search "Big Bad 1JZ swap in sc400"
