SC- 1st Gen (1992-2000)
EGR delete; resistor custom made, pic...
Old 02-04-10, 02:27 PM
sc300Super
sc300Super's Avatar
Default EGR delete; resistor custom made, pic...
96, SC300, I changed valve cover seals (parts from dealer) and spark plugs(NGK PK6EB11, $7 each). Next I'm doing EGR block off. I used 2 plates to blocked off EGR and I made custom resistor for EGR sensor plug-in. What do you guys think?
Attached Thumbnails EGR delete; resistor custom made, pic...-picture-021.jpg   EGR delete; resistor custom made, pic...-picture-022.jpg   EGR delete; resistor custom made, pic...-picture-023.jpg   EGR delete; resistor custom made, pic...-picture-024.jpg
Old 02-04-10, 02:31 PM
masagsxr
masagsxr's Avatar
Very cool.. Custom made resistor huh... How? Whats the resistor value?
Old 02-04-10, 02:34 PM
TLDriver
TLDriver's Avatar
good idea just the "what if" part of me is thinking what if for whatever reason it stops making contact or if the resistor goes bad (doubt it will ever go bad)
Old 02-04-10, 06:17 PM
jadu
live.love.laugh.lexus
jadu's Avatar
looks like an axial resistor under the blue thing, what is that blue thing?
Old 02-04-10, 08:12 PM
sc300Super
sc300Super's Avatar
the blue thing is silicone hose 3mm. I used super glue.
Old 02-08-10, 02:46 PM
sc300Super
sc300Super's Avatar
Default EGR delete, intake manifold mod
I took pictures of intake manifold, inside IM I took out pippe and blocked off with oil drain plug.
Attached Thumbnails EGR delete; resistor custom made, pic...-picture-042.jpg   EGR delete; resistor custom made, pic...-picture-043.jpg
Old 02-08-10, 04:03 PM
jadu
jadu's Avatar
glad u took off that pipe in the middle. I saw it in there when i took mine off and looked like it just restricted air flow. what did it do again?
Old 02-08-10, 04:08 PM
That-Guy
That-Guy's Avatar
i took the pipe out as well when i went through my egr delete... it was one son of a B&*^H to get out. And i went through about 12 cans of b-12 cleaning all the gook out of the whole intake interior.
Old 02-08-10, 04:36 PM
sc300Super
sc300Super's Avatar
yes indeed, it took me 1hr to take the dam thing out, it was so bad inside. now i'll have better air flow in the IM.
thoes of you who did EGR delete, what did you do on last picture(tubes near fire wall)? I didn't bother to take out the hard lines under very last IM, so i just decided to plug it or connect. Do you guy know what tube I plug or connect? appreciated if you help me out or pictures.
thank you
Attached Thumbnails EGR delete; resistor custom made, pic...-picture-041.jpg
Old 02-08-10, 08:17 PM
sc300Super
sc300Super's Avatar
anyone did egr delete?
Old 02-08-10, 08:26 PM
5sp_jzz30
5sp_jzz30's Avatar
congrats. did this like 2 years ago.
if you search you should be able to find my thread with pictures and description. instead of a drain plug i went to NAPA and got a freeze plug. i had the part number and size posted as well.
when i did my egr delete i removed all the VSV's as well as the vacuum canister underneath the intake manifold. i also removed all the unnecessary vacuum hose, which is pretty much all of them.
the only ones i have left on my intake manifold is fuel pressure regulator, heater valve, and brake booster.
used a 10,000 ohm 1/2 watt resistor. have never had check engine light issues.
joe diego (02-20-20)
Old 02-08-10, 09:57 PM
sc300Super
sc300Super's Avatar
i'll try take most of them out, thanks 5sp.
sc300Super
Performance & Maintenance
27
04-12-17 09:20 PM
t2d2
07-03-14 07:00 PM
mk4r34
04-23-13 02:16 PM
DRFT103
02-09-10 09:34 AM
thebeeguy
09-29-07 10:03 AM
Quick Reply: EGR delete; resistor custom made, pic...
