SC- 1st Gen (1992-2000)
Help! AIR BAG light is on after battery change
Old 07-16-10, 06:18 PM
  #46
okbobbo
okbobbo's Avatar
I would try the Camry forum.
Old 07-01-12, 08:23 AM
  #47
mmartin888
mmartin888's Avatar
party party after 28000 tries I did it light is off, after reading about ground I took jump cables and just connected to negative side of battery and set the other side in floor, someone posted to do this and after two tries airbag light did its thing and is off.
Old 09-14-19, 06:02 PM
  #48
meinoc
meinoc's Avatar
Thanks for followed you steps and worked perfect on 1993 SC400.
Old 01-06-21, 06:53 PM
  #49
lichennj
lichennj's Avatar
Good instruction, Successfully fixed the airbag light due to taken the steering wheel out to finish leather. On a 92 ES300, you can see the progress by looking at the dash when jumping to Tc, the airbag light will light quick after the cruise and ABS light. Before jumping the wire if Tc is connected to ground, the cruise will flash then ABS will flash, followed by the airbag indicate the fault code (14) for my case. When you jump till the stage that when Tc is still connected before you switch to another AB, you could have the chance to see the airbag light, that's what indicates you are good. I tried 5 times then finally figured out the rhythm, almost give up in this -15 degree winter lol. (you can insert multimeter needle directly into the socket, and use the driver side door latch as ground, that's better than connect to battery)
ohiois350
02-13-18 07:12 PM
vernhc
RX - 1st Gen (1999-2003)
01-06-18 10:44 AM
jcboiz
12-16-12 07:41 PM
logicalman
Performance & Maintenance
12
07-07-09 03:16 PM
katz
03-17-03 06:09 PM
Quick Reply: Help! AIR BAG light is on after battery change
