11-05-09, 11:29 PM
Seat adjustment memory buttons not working
I've been meaning to ask this question for a long time now, and I finally remembered to start a thread about it. Anyway, on my 94 SC300 on the driver's door panel there are 3 buttons for adjusting the seats. There is a 1, 2, and set button. I push these buttons and they don't do anything. First of all, what do these buttons even do exactly lol? Is there some kind of combination to push these buttons to make the seats move or whatever? If not, how could I fix this to make it work?
11-05-09, 11:43 PM
I found that it only works when its in park. Hold the set button and press either number to set. Hope that helps.
__________________
'92 sc400 - stock
'89 240sx coupe - ca18det
11-05-09, 11:48 PM
Yeah I could try that, but if that doesn't work I guess I'll check the fuse for it or something. Thanks.
11-06-09, 05:16 AM
Isn't this a SC400 thing only? I think if you were take take your door panel off there'd be nothing plugged into the back of that memory switch.
I've taken the doorpanel off 3 Sc300s that haven't had that plugged in.
11-06-09, 05:32 AM
I concur with RyanV, the cord is really short for that connector. So when you put your door panel on, that's the last thing you do and it's easy to forget. My car had the same issue when I bought it, just had to reattach it.
11-06-09, 10:14 AM
But the last time I checked the wiring looked hooked up. I guess I'll look again and see if it is or not.
11-06-09, 10:58 AM
Car must be in park and the e-brake must be up as well. That is the only way this will work. I have it in my SC300. Press the set button along with 1 or 2 to set that button for where the seat is currently positioned. If the seat ever moves just put it in park, put the e-brake up and press either 1 or 2 and the seat will go into that position. Took me awhile to figure this out too.
__________________
Sylvania Bulbs, Puddle lights, 20" Status Knight 5 spoke: 8.5 f 10 r, Supra Tokico/Eibachs, Magnaflow 14829's, Front strut bar, Black Painted Front and Rear Calipers with white Lexus Stickers on the fronts, Blacked out chrome window trim, Black Smoked Tailights, Tints, Honda S2K Antenna, Wood Dash kit, Three Spoke Steering Wheel, Black/Tan interior, Carputer, GS Door Sills, Black Badges, Clear Sidemarkers
http://www.clublexus.com/forums/sc-400-300/366258-pics-of-my-97-sc300-in-the-813-a.html Progress pics of the car.
11-06-09, 11:57 AM
Cool thanks I will try that now.
11-06-09, 12:01 PM
Quote:
Not a problem....let me know how it goes.
__________________
http://www.clublexus.com/forums/showthread.php?t=366258 Progress pics of the car.
11-06-09, 01:25 PM
Yeah turns out that did work for me. I pushed the set button with the number 1 button and it made a beeping noise and set my current seat position. Only problem is I tried it with the number 2 button and it beeps just like the number 1 button but it does not move the seat when you move it out of its set position. Any ideas?
11-06-09, 01:34 PM
Quote:
Nope, I have an SC300 and my memory seats work just fine.
__________________
*Starts to breakdance on floor*
11-06-09, 03:35 PM
Hmmm....not sure about the number 2 button not working. I never really use number two so I don't really worry about it. At least number one works!!! Haha....
__________________
11-06-09, 07:14 PM
Quote:
LOL qft my friend!
11-17-09, 01:20 PM
what about for a 5spd? we dont have a park... and mine dont work either hahah
11-18-09, 08:26 PM
1993 Lexus SC
What works for me
Rooticon,
After you have set Button #1, with the key turned to on, parking brake on, trans in Park, use the lever on the side of the seat to move it all the way to the rear, then set button #2. This allows you to exit and enter easily and hit #1 to go driver's position. Its helpful in tight spaces due to the extra long doors on our cars.
__________________
93 SC400 - LLS Gauge Cluster, 20% rear and side tint, BFI 3.3 Kit, SEM, Homelink in visor, 178,000 miles. SUPPORT OUR TROOPS - www.MILITARYTUNERS.COM
2007 Camry XLE V6 for wife, 350Z Roadster for daughter, & Frisbee for Heidi, SC, CGC, TDI
Tags
2000, driver, es, es330, fix, gs430, gx, lexus, memory, position, problems, seat, set, system, working  |
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
