SC- 1st Gen (1992-2000)
is300 steering wheel upgrade..
Old 11-15-12, 08:07 PM
  #106
IN2LXUAL
IN2LXUAL's Avatar
the wheel will fit, the wood wont match, and you'll need a single stage airbag.
Old 01-02-13, 01:37 AM
  #107
1WILLY1
1WILLY1's Avatar
does anyone have any info on the rx300 wheel swap?
Im pretty sure thats what sherm did on page 2 or 3.
Old 09-29-13, 06:06 PM
  #108
Vrank
Vrank's Avatar
So I modified the auto is300 e-shift buttons to become the actual cruise control functions. Was pretty easy. Four separate switches, perfect if you look at diagrams. Eliminate the stalk, cleaner look imo. can always have the buttons carbon/wood/color dipped, or not give a ****! Horn works, everything else should. Waiting to find a guinea pig as gf's sc doesnt have a cruise control cable and is getting an rx tan/wood wheel, so this one was only fit to test initial function and is now for sale.
P.S.
My airbag light is on because I don't have the adapter. VIDEO BELOW, DON'T KNOW HOW TO EMBED
http://www.youtube.com/watch?v=NxSt3...ature=youtu.be
Old 10-09-13, 06:30 PM
  #109
bigwhite
bigwhite's Avatar
Im not using cruise and would be happy without airbag since my car is going for lightweight.. Do need a new steering wheel.
Old 10-09-13, 07:46 PM
  #110
Biddles
Biddles's Avatar
The IS wheel is nice, but are there any Black 3 Spoke Wheels with Wood that matches the SC wood?
Old 10-10-13, 07:15 PM
  #111
bigwhite
bigwhite's Avatar
Did any of the IS wheels come in something besides black.
Old 10-10-13, 10:02 PM
  #112
CalitriSC
CalitriSC's Avatar
Is there a list of the airbags that can be used with the IS 300 steering wheel?
Old 10-11-13, 12:43 AM
  #113
KahnBB6
KahnBB6's Avatar
Received 1,216 Likes on 854 Posts
All these three-spoke steering wheels and airbags are interchangeable and basically the same. Most have leather wrapping in black. Some are perforated and some aren't. The IS300 wheel is unique in that most of them have shift buttons. You will need a convertor connector cable from Toyota/SPX to plug the airbag directly into your SC airbag harness.
An easy way to get a "manual" wheel is to buy one of the leather ones from one of the following Toyotas and use an IS airbag if you want to have the "L" logo.
2001-2005 IS300
1998(?)+ Toyota Rav4
All years MR2 Spyder
1st gen Toyota Matrix XRS
1st and 2nd gen Corolla XRS
1998 Supra
The airbags themselves have the same hardware inside. On the outside the IS300 airbag has the most differences. The 1998+ RAV4 airbag and 1998 Supra airbag are very similar to the IS300 in shape but obviously have only a plain Toyota symbol.
Old 10-12-13, 06:46 PM
  #114
CalitriSC
CalitriSC's Avatar
Great thank you.
Old 10-15-13, 01:04 PM
  #115
xECKSx58
xECKSx58's Avatar
Just installed my RX300 steering wheel. Got it on eBay for $180 shipped (it came with the airbag).
Only thing wrong with it is that it didn't come with the plastic covers that cover the airbag bolts, but I can get those from Lexus for about $7 for both so that's no worry.
Haven't plugged the airbag in yet, I'm gonna order the adapter instead of just changing the plug from the RX to the SC wheel (just to keep all the parts together). Plus the adapter is only $20 from this website http://www.handsontools.com/OTC-Tool...-_p_49780.html
I also haven't swapped the cruise control lever out because the cruise control wasn't working with the old steering wheel anyway. After I got a remote starter installed the cruise would arm but wouldn't set. I'll probably swap the cruise control over when I install the airbag adapter anyway though.
Old 05-09-15, 06:36 AM
  #116
megamax
megamax's Avatar
bumping this thread because I need some insight. hopefully I can finally get a response.
so I picked up a whole steering wheel/airbag from a 01 Toyota celica.
I also found a 97 sc300 wheel and I took it off for comparison(mind you I have a 1994 sc400) bit things should be the same. here is the airbag config of the sc300
and here is the wire setup from the celica
the splines are the same(of course). but iam looking at the hubs and they look different(do I need the celica hub)?
I picked it up anyway but it feels flimsy compared to the sc's.
here is the sc one on the left
here are the backs of them
I have the pigtails from both wheels and I plan to solder the end piece into my wheel column. so guys, do I need the celica hub or can I use the hub on my car?
Old 05-10-15, 05:51 AM
  #117
megamax
megamax's Avatar
anyone?? am I invisible here??
Old 05-10-15, 10:48 AM
  #118
LoveSCs
LoveSCs's Avatar
I installed an IS200 wheel onto my 95 sc400 not too long ago. I left the SC hub on, and bought the airbag sub harness connector to adapt the SC clip to the clip on the IS wheel. I also cut the wires for the cruise control because I don't use it.
Old 05-10-15, 10:55 AM
  #119
LoveSCs
LoveSCs's Avatar
connector adapter is part number 09082-00760. I bought it from handsontools
Old 05-10-15, 05:56 PM
  #120
megamax
megamax's Avatar
what
about
the
horn??
Quick Reply: is300 steering wheel upgrade..
