07-25-09, 12:27 AM
Old headlights/projectors vs New headlights comparison PICS
Just finished my retrofit and I found out one of my headlight has been replace with a newer one with the update projector.
Heres a few pics comparing the old and the new for those who are interested.
I just shined a led flashlight through the back of the projector.
old
back
****ty pic, sorry. Hard to hold everything with both hands.
You can see the narrow and uneven pattern, not a good idea to stick plug and play hids kits in these. I had them my old soarer and the glare was pretty bad.
new
Nice wide even pattern with a sharper cutoff in the new one. Should be ideal for a quality plug and play kit.
Only problem I see is the square light at the upper left hand corner. You can probably block it off.
07-25-09, 12:32 AM
1995 Lexus SC
Invaluable info, thanks for the write up. I'll keep this in mind when I grab a set of HIDs for my SC.
What's up with the small block? Is that where the turning signal is supposed to be?
__________________
1995 LEXUS SC300 2DR COUPE
[4K9] --> Sandstone Beige Metallic
18" 350Z 35th Anniversary wheels / SC400 front spoiler /
Matte black emblems / 30% window tints
07-27-09, 09:33 PM
the small block is for lighting up street signs I think
07-27-09, 10:30 PM
do you have the part number of the NEW headlight? not just the projector.
07-28-09, 12:36 AM
Those squares inside the projector cause this glare above the cutoff line. My headlights are factory from 1998.
__________________
Keepin' It Clean!
LOL
07-29-09, 07:40 AM
1999 Lexus SC
Quote:
Whoa.. I have a '99 and mine look NOTHING like that. No glaring at all above the cutoff line except for the cool "rays" from the city lights. I'll have to get a pic.
__________________
At no point in your rambling, incoherent response did you come close to anything that could even be considered a rational thought.
11-08-09, 07:55 PM
So I went ahead and took care of the problem, all I did was simply stuff some aluminum foil in that hole to completely block off the squares.
__________________
Keepin' It Clean!
LOL
11-08-09, 07:56 PM
Here is a picture of the the hole blocked off.
__________________
Keepin' It Clean!
LOL
07-28-09, 12:50 AM
Nice.
Dig it.
__________________
07-28-09, 07:54 AM
Good idea, great writup... too bad I just took both of mine apart and redid them completely.. I used O.L.T. method, and I love them again. I will have to keep this one in mind, if theres a next time!
__________________
1992 Lexus SC400
2002 BMW 330i
ROLL TIDE ROLL !!! Watch out Florida!
07-28-09, 01:12 PM
The new style projectors are definitely better for use with a pnp kit. All you have to do is cover up the small hole (w/ tape, thin piece pf flash aluminum, anything else that you can think of), and your good to go.
07-28-09, 01:31 PM
Is it possible to open it up completely and insert a custom cutoff piece?
__________________
1995 SC300 Red/Tan 5spd (Boosted Daily)
07-28-09, 05:14 PM
edit: nevermind, seeing things. Honestly I like the old ones.
I adjust both lights so that they overlap a little, so you dont notice that the middle part is lower.
its pretty close to a flat line on the old ones.
Also seems like they shoot more light on the corners on the ground which I like more.
__________________
07-28-09, 06:38 PM
1995 Lexus SC
in the 3rd pic 1jztts posted, ( all that uneven crap thats sits in front of the bulb) i went and cut out all of it, its been about a month now and no probs with the po pos, does anyone know if doing thats illegal?
__________________
95' Sc4
11-08-09, 08:07 PM
Nice, I would of left the square hole. IMO.
__________________
__________
95 SC300
2JZ-GE( NA-T),T61,SSAutochrome turbo manifold, custom 3" downpipe(heat wrap), 2.5" IC piping(heat wrap),FMIC, Greddy turbo blanket, Greddy turbo timer,Greddy Type-RS BOV, Apex'i Neo II,Apex'i Dual exhaust, HKS wastegate, 362whp/350tq
"I NEVER had stock TWINS"
Tags
chart, club, comparison, cut, headlight, headlights, is350, lap, lexus, projector, projectors, sc400, style, uneven, working  |
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
