SC- 1st Gen (1992-2000)
How to PAINT your wood grain and REMOVAL
Old 03-24-09, 12:02 PM
evilninja
evilninja's Avatar
I have a black interior car, and would like to blacken it out completely by spraying the woodgrain as well. Did you coat the paint with some enamel, clear coat, or polyurethane? The last time I tried to spray paint something, I didn't do so evenly, any tips on achieving an even spray? Like try not to spray too close to the object? Thanks for this write up!
Old 03-24-09, 12:53 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I did not spray any other type except for the primary color of the paint itself. Just the satin finish black from Krylon Fusion. I made sure there was absolutely no armor all on any part of it. The best way to paint something, is by starting with the sanding. Sanding is the most important. Im my opinion. When you think you sanded it enough, sand some more. Use even strokes with the sandpaper, not round and round. I found out this caused too mant swirls, and then later had to go back with 800 grit to get those swirls out. Use back and forth motion, with not alot of pressure, just even pressure. Once its sanded and cleaned, then you can spray it. Dont get too close, and use even coats of paint. Keep about 6-8 inches from the piece and the nozzle. Do several light coats! Not a bunch of heavy ones! I sprayed each piece about 5 times to achieve the color and tone of it. The pictures you are viewing is without nothing on them. No armor all or anything. Just the color and finish that I was looking for! They do make high gloss, but I thought it would be too much. Just take your time and it will turn out right. Another tip to remember is between each coat, make sure there is no dust or any particles on it before you spray again. Pollen is everywhere now. Lastly, the reason I used this type of paint, is that it sprays well, and looks good. Remember also between each coat that you turn the can upside down and spray it, this is to relieve the air inside the can, and to help keep the nozzle clean! If you notice the paint blotting and you see it not spraying correctly, replace the can, or change out the nozzle. This will assure proper spray and to keep it evenly.
tc32
tc32's Avatar
good job... considering giving this a try
Old 03-24-09, 01:02 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thanks fella's for all the compliments.. Keep the posting going... Good luck with all of your color choices and whtever you decide to with it! The most important thing to do is sand, sand, sand, and sand.... Lastly, when you decide to pull the middle wood trim out, do so evenly, NOT just one side, this will help keep from cracking or breaking the center set of vents... Learn form me and my mistakes! Sometimes, super glue is your best friend.
Old 03-24-09, 02:28 PM
Cleanshots
Cleanshots's Avatar
not glossy.... you want this Name:  DSC00995.jpg
Size:  72.4 KB and this Name:  DSC00996.jpg
Size:  50.3 KB more on my wood trim thread, see my sig...
Old 03-24-09, 02:33 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thats amazing looking wood trim... It was your post that gave me the idea to give it a try. I wanted to elaborate more on how to remove and install...
Old 03-24-09, 05:51 PM
SpiderN9NE
SpiderN9NE's Avatar
Post yea yea
yes'em, this is just what i needed. the bad thing is i keep changing my mind on my paint so i can do it till i decide
Old 03-24-09, 06:12 PM
felixsc300
felixsc300's Avatar
Very nice write up. The black contrasts nicely with the gray.
Old 03-24-09, 06:19 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thanks man. I appreciate all the comments...... Let me know if I can help anyone out!
Old 03-24-09, 06:51 PM
Amini9
Amini9's Avatar
what paint do u use?
Old 03-24-09, 07:20 PM
ThomasGS4
ThomasGS4's Avatar
bleh too many things to remove lol
Old 03-25-09, 08:14 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I used the Satin Finish Krylon Fusion paint from Wal-Mart. They also had high gloss, but I thought it would be too glossy for the matching of the rest of the interior. You can use whatever color you like, but I thought this color scheme was best for the grey interior.
Old 03-25-09, 08:17 AM
farquad
farquad's Avatar
woa, your interior looks to be in mint condition.. nice writeup
Old 03-25-09, 08:24 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I try to keep it as clean as possible. I have a little crack on both door panels that need some attention, but other than that it looks pretty clean. I also had all the seats repaired, filled, and resprayed to make it look good again. If this doesnt hold, it will be time to call leatherseats.com, but so far so good. I am happy with what the local guy had done with it... Thanks again for the compliments, and keep the posts coming! I love your LS...
Old 03-25-09, 09:49 AM
AD_SC3
AD_SC3's Avatar
Thanks for the write up. Now I need to decide on a color
Quick Reply: How to PAINT your wood grain and REMOVAL
