SC- 1st Gen (1992-2000)
Can I fit 305/25/20 on my sc400
Old 03-12-09, 07:38 PM
joeazy187
joeazy187's Avatar
Default Can I fit 305/25/20 on my sc400
I was wondering if I can fit 305/25/20 on the rears with 10" wide rims and a factory suspension, thanks.
Old 03-12-09, 07:56 PM
durtysc300
durtysc300's Avatar
im sure you could..but idk why it'd look pretty donktastic on stock suspension/body
Old 03-12-09, 08:34 PM
joeazy187
joeazy187's Avatar
you think I'll have room to lower it with those wheels?
Old 03-12-09, 08:44 PM
One HoT
One HoT's Avatar
Why do you want to put a tire thats wider than what the rim can hold? I would imagine the sidewall begin much taller if you do a 305 on only a 10 inch wide wheel. I think it would be a better idea to put a 275 or 285 sized tire on a 10 or buy a 11" wide rim to accommadate the wider 305 sized tire..
Old 03-12-09, 09:58 PM
rogsc400
rogsc400's Avatar
This very true......
I run a 275/30/20 on my rear with a stock body.....i had to roll the the fender a little to make it fit with no rubbing.....that 305 tire is gonna be tuff but any thing is possible if you try...
Old 03-12-09, 10:50 PM
joeazy187
joeazy187's Avatar
well I was just curious cuz I have 2 305/25/20 tires that I had lying around from a car I used to have and since they are in really good condition I was wondering if they fit I could use them but since it sounds like they dont I'll just sell them, no biggie .
Old 03-13-09, 12:53 PM
Brendon
Brendon's Avatar
Rim range for anything above 295 is 11"+. 10" is gonna be tough on the tire. It'll be bulging out, producing a weak sidewall. Honestly you'll probably see much better performance if you mount a narrower tire on. Usually you want the tread to be equal or narrower than the rim's width for maximum performance.
Globalinx
12-15-11 07:49 PM
msgs350
05-19-10 01:55 PM
Kyle Harty
Wheels, Tires & Brakes Forum
09-07-08 07:42 PM
ej20child
05-26-08 05:55 PM
J J
Suspension and Brakes
14
01-19-06 11:00 PM
Quick Reply: Can I fit 305/25/20 on my sc400
