take apart key?
I did this to replace the battery also. You are right with your thinking but do be careful when you are pulling it apart after the screw is out. Just get a tiny screw driver and pry around the border of the key fob. It should pop off eventually. Hope this helps.
I actually took my key apart about 3 times in the last couple days to get the battery size and replace it. It has a notch that goes in toward the plastic near the keychain part of the key. Best bet would be to pry it open by the metal key slightly and slide it backward toward the keychain part. Mine was pretty solid though - didn't seem like much of a chance for anything to break unless I would've tried prying it open by the keychain.
Jeembo's description of the key disassembly process is correct. Be sure to use a small phillips screwdriver to avoid damaging the screw or stripping the threads in the key assembly. The replacement battery required for the key that is compatible with 1995 SC's is type BR1216.
Last edited by SleeperTTz; 10-18-11 at 05:38 PM. Reason: found the answer in the above post...
