SC- 1st Gen (1992-2000)
DIY SC300/400 clear corners for $20. Lots of pics
Old 09-03-08, 05:26 PM
Billy305
Billy305's Avatar
Post DIY SC300/400 clear corners for $20. Lots of pics
Someone requested that I take pictures when I went to install/modify my gs300 side markers to fit my sc300. I had time to do it this weekend and took alot of pics. I think it turned out pretty well. I know that everyone doesnt like the clear look but here goes.
These are side markers you can buy on ebay that are made for a gs300. I bought these for 20 dollars shipped. They came with a chrome covered bulb that looks silver when its off, but lights up orange.
As you can see they are the same height. The clear markers are just a little bit longer than the stock ones. I took a sharpie and a peice of paper and wrapped it around to make an outline.
Take the paper back off the light and cut out the outline of the marker. Once you cut it out, take some clear packing tape and center the paper on the new markers. When you do this leave an even amount of space to be cut off on each side. You are going to basically just trim off what isnt paper. The tape also helps to hold everything in place and prevent chips.
As you can see you only have to trim off a little bit.
The trick is that you will have to grind the plastic down with the dremel at an angle. The very front of the marker will be the widest and as you trim towards the plug you need to go at an angle. You will also need to take the screws off the back of the new marker as they will not match up with the stock holes. One thing I would like to mention too is that grinded plastic is hot as %$@* so make sure you are careful not to get it on your hands.
After grinding away and test fitting a couple times you will finally get it to fit in snug. I used an adhesive silicone to both seal and attach the marker to the car. You will need to seal up the sides where you grinded and then use the same stuff on the back and press it into place. I would recommend you let the car sit over night to let the silicone dry. Once installed heres how mine look day and night time below.
Billy305
Billy305's Avatar
Old 09-03-08, 05:29 PM
TheMole
TheMole's Avatar
Great job!
Old 09-03-08, 05:55 PM
Curry
Curry's Avatar
Looks good! Gonna give this a shot too when i get some time.
Old 09-03-08, 06:08 PM
TroySC300
TroySC300's Avatar
I'm not seeing the step where you removed the orange lens and made it clear?
Old 09-03-08, 06:10 PM
P.R.S.22
P.R.S.22's Avatar
Finally someone posted a DIY thread about this. Great job. I ordered mine a few days ago so once I get them in I will put them on and post some pics as well. Did you get to the sidemarkers by going in through the front fenders where the tires are?
Old 09-03-08, 06:11 PM
Billy305
Billy305's Avatar
These are two different lights. The orange ones are the stock from my car. The clears ones are from ebay and came clear.
Old 09-03-08, 07:39 PM
PecosBill
PecosBill's Avatar
Looks awesome, great writeup.
Those IS rims look great
Old 09-03-08, 07:44 PM
aka paco
aka paco's Avatar
nice job, lovin the silver 97+ too
Old 09-03-08, 07:55 PM
//LRD
//LRD's Avatar
on a job well done.A couple guys were talking about this at tower shop last Friday.
Old 09-03-08, 08:34 PM
<>sonmylex
<>sonmylex's Avatar
great diy.. can i ask what seller you purchased these from?
Old 09-03-08, 08:39 PM
Hil
Hil's Avatar
Nice, good job. I may do this later
Old 09-03-08, 08:50 PM
TroySC300
TroySC300's Avatar
OH, wow I feel dumb. I have those same gs clear corners in my closet... I'm going to do this next weekend
Old 09-03-08, 09:02 PM
skousenjr
skousenjr's Avatar
yea im looking cant find the ones with those bulbs
Old 09-03-08, 10:05 PM
IndecentSC
IndecentSC's Avatar
i just order mine..thanks for the write up
Quick Reply: DIY SC300/400 clear corners for $20. Lots of pics
